I'm not sure what the problem is in your case, but I don't think your truck should have solenoids. I think they started in 96 when everyone went to OBDII. It should still be a straight juice (hydraulic) transmission. Why did you have to change the input shaft? Was your original tranny a non lockup? Is so, why didn't you just change the TC and all and make it a lock up?
I replaced the solenoids in my 96 tranny cause the symptom was because it would hang onto gears like it was in eternal kick down mode. I would have to take my foot all the way off the throttle to make it shift, sounds like you have a different problem
