Steel Rim Fix-up? #1187255
02/27/12 07:03 PM
02/27/12 07:03 PM
North Carolina
Mikeymopar68 Offline OP
North Carolina
I am cleaning up some painted steel rims to sell to a friend. When I took the tires off the rims there was more than the expected rust along the bead area and the rim edge and around the valve stem hole. The tires held air so I will assume the rims are acceptable for use. I took a wire wheel to those areas and broke the rust loose and then I treated it with a rust stopper which turns the rust to a black oxide. My question is; Is there a product I can spread over the pitted areas , sand down, prime and still have it hold up without cracking and popping loose and still look presentable? Thanks Mike
Re: Steel Rim Fix-up? [Re: Mikeymopar68] #1187256
02/27/12 07:36 PM
02/27/12 07:36 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Sounds like you want to hide the rusted areas, why ? I would let the end user decide how they want to treat those areas.
Re: Steel Rim Fix-up? [Re: JohnRR] #1187257
02/27/12 10:21 PM
02/27/12 10:21 PM
North Carolina
North Carolina
Just trying to make the rims presentable is all!
Re: Steel Rim Fix-up? [Re: Mikeymopar68] #1187258
02/27/12 10:26 PM
02/27/12 10:26 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
I would use a product like All Metal filler. Fill the pits, sand it smooth, prime, then paint.
Re: Steel Rim Fix-up? [Re: Dave Watt] #1187259
02/27/12 10:31 PM
02/27/12 10:31 PM
North Carolina
North Carolina
Thanks Dave I forgot about that stuff!
Re: Steel Rim Fix-up? [Re: Mikeymopar68] #1187260
02/28/12 02:54 AM
02/28/12 02:54 AM
JohnRR Offline
JohnRR  Offline
If they are that bad that you need to hide their condition from your friend maybe you should ask yourself if him being your friendship is more important than the money?
Re: Steel Rim Fix-up? [Re: Mikeymopar68] #1187261
02/28/12 05:06 PM
02/28/12 05:06 PM
GMP440 Offline
GMP440  Offline
Just sand blast the wheel, put a good primer on it and paint. I just redid a wheel about a month ago. Mine had some surface rust with a little pitting, but came out really nice.
Re: Steel Rim Fix-up? [Re: GMP440] #1187262
02/29/12 12:46 PM
02/29/12 12:46 PM
North Carolina
North Carolina
Thanks Guys for all your advice all except for JohnRR. Normally I ignore stupidity and so I will in this case to continue my run of ignoring an IDIOT JohnRRu. To even suggest I am trying to hide something is about your speed!!!! Thanks to everyone else. I learned something once again.
Re: Steel Rim Fix-up? [Re: Mikeymopar68] #1187263
02/29/12 04:37 PM
02/29/12 04:37 PM
JohnRR Offline
JohnRR  Offline
Seems I struck a nerve , obviously the TRUTH hurts ...
I wonder if your FRIEND will be very happy with the outcome of the PERFUMING of those rims?
Re: Steel Rim Fix-up? [Re: JohnRR] #1187264
02/29/12 05:36 PM
02/29/12 05:36 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
cologning?
Re: Steel Rim Fix-up? [Re: srt] #1187265
02/29/12 06:20 PM
02/29/12 06:20 PM
JohnRR Offline
JohnRR  Offline
lipstick on a pig ?
Re: Steel Rim Fix-up? [Re: JohnRR] #1187266
02/29/12 11:13 PM
02/29/12 11:13 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
I agree with John on this one. I may try and clean them up if I was going to use them, but not for resale, especially to a friend. I've bought stuff with hidden damage at swap meets and was more than a little pizzed when I found it later on. Go ahead and sell it to your buddy, just expect that you may have to look for some new friends.
Re: Steel Rim Fix-up? [Re: B5 Bee] #1187267
02/29/12 11:19 PM
02/29/12 11:19 PM
Texas
Ron69rr Offline
Ron69rr  Offline
Texas
Friends are harder to find than parts.
