Best Repro Hemi Booster Bracket assembly #1184274
02/22/12 08:44 PM
02/22/12 08:44 PM
Sacramento, CA
viperdude99 Offline OP
Sacramento, CA
Asking the membership - I'm building a 71 hemi cuda convertible clone with shaker. Not a real car obviously, but its coming out pretty decent. Because I'm not getting response from Mr. Newcomb on his (that I already paid for unfortunately), I now need to purchase a replacement. Because of the project I have narrowed down my need to either Booster Dewey or Ramman. Thoughts on product? Price? Thanks for any feedback!
Re: Best Repro Hemi Booster Bracket assembly [Re: viperdude99] #1184275
02/22/12 09:47 PM
02/22/12 09:47 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
If correctness is what your after regarding the Hemi Brake booster bracket, contact Wayne/Ramman, be aware that you'll need a HEMI specific booster to fit the brackets, as the bolt diameter and pattern are different than the standard Bendix dual diaphram boosters
Here's RAMMAN's set-up $995
Re: Best Repro Hemi Booster Bracket assembly [Re: DAYCLONA] #1184276
02/22/12 09:56 PM
02/22/12 09:56 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Or you can pony up for this original set-up on EBay currently, all set up for a 70-1 E body...$1250
Re: Best Repro Hemi Booster Bracket assembly [Re: viperdude99] #1184277
02/22/12 10:02 PM
02/22/12 10:02 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
FYI...I assume your running disc/drum?, if so the "correct" disc/drum master for your 71 clone is casting # 2229191
Mike
Re: Best Repro Hemi Booster Bracket assembly [Re: DAYCLONA] #1184278
02/22/12 10:18 PM
02/22/12 10:18 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I used the Booster Dewy booster rebuild combinded with Dr Diff's brackets.
I don't remember the price but it was very affordable + 90% of the people can't tell the difference
Re: Best Repro Hemi Booster Bracket assembly [Re: gtx6970] #1184279
02/22/12 10:25 PM
02/22/12 10:25 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Bill,....I may be wrong, but IIRC Doc Diff's brackets are for the "standard" Bendix Dual diaphram boosters that get the booster pushrod modified for the proper stroke
Re: Best Repro Hemi Booster Bracket assembly [Re: DAYCLONA] #1184280
02/22/12 11:50 PM
02/22/12 11:50 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I make both styles.
Re: Best Repro Hemi Booster Bracket assembly [Re: DAYCLONA] #1184281
02/23/12 12:19 AM
02/23/12 12:19 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I make both styles.
Good to know in case I end up putting the Hemi in the Bee and I don't want to waste a g note plus on a booster
Re: Best Repro Hemi Booster Bracket assembly [Re: DAYCLONA] #1184282
02/23/12 09:12 AM
02/23/12 09:12 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Correct.
When I did this car my customer was not after 100% dead nuts appearence . He was after 'The look' and Cass's brackets along with the modified booster all is good on our end.
Everyting done and on the car and he is WAAAAAAYYYYYYY under the buy in price on a 'correct' Hemi booster setup and brackets
Re: Best Repro Hemi Booster Bracket assembly [Re: gtx6970] #1184283
02/23/12 10:25 AM
02/23/12 10:25 AM
JohnRR Offline
JohnRR  Offline
Correct.
Bill who does the booster mod ?
Re: Best Repro Hemi Booster Bracket assembly [Re: JohnRR] #1184284
02/23/12 10:30 AM
02/23/12 10:30 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Booster Dewey did mine.
I told him I had Cass's brackets and he modified the booster as needed.
It's on the car and every single piece fit and works perfect.
I can try to get some pictures later today if needed, as I have the car back in to fix some bugs.
But it might be tomorrow as I have a funeral to attend this afternoon.
Re: Best Repro Hemi Booster Bracket assembly [Re: gtx6970] #1184285
02/23/12 01:40 PM
02/23/12 01:40 PM
North Central USA (MN-WI area)
MuscleMopars Offline
I have an original unit complete sitting on my shelf. Well, here it is on the floor. It might be available?
Thanks,
Eric
email eric@musclemopars.com
715-426-HEMI (Shop)
612-669-CARS (Cell and Texts)
Go to my Moparts "Profile" to see my web site
Re: Best Repro Hemi Booster Bracket assembly [Re: gtx6970] #1184286
02/23/12 02:46 PM
02/23/12 02:46 PM
JohnRR Offline
JohnRR  Offline
Thanks , no picture is needed at this point .
Re: Best Repro Hemi Booster Bracket assembly [Re: JohnRR] #1184287
02/24/12 04:11 PM
02/24/12 04:11 PM
Sacramento, CA
Sacramento, CA
Thanks for the great feedback all. Wayne (Ramman) told me that some of the setups out there may result (due to bracket geometry) in only 80% pedal/brake pressure?? Looks are important but function is REAL important. Btw, I'm running factory disc or front, with Cass's disc brake set up in the rear.
Re: Best Repro Hemi Booster Bracket assembly [Re: viperdude99] #1184288
02/24/12 04:32 PM
02/24/12 04:32 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
I have a reproduction e-body set up from one early supplier in Arizona that I bought and didn't use and is available. I finished my 71 hemi convertible and it was a part left over and It's setting on the shelf unused.
PM if interested, reasonable.
logan426 618-322-7587
