Re: Best Repro Hemi Booster Bracket assembly
[Re: gtx6970]
#1184279
02/22/12 10:25 PM
02/22/12 10:25 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I used the Booster Dewy booster rebuild combinded with Dr Diff's brackets. I don't remember the price but it was very affordable + 90% of the people can't tell the difference
Bill,....I may be wrong, but IIRC Doc Diff's brackets are for the "standard" Bendix Dual diaphram boosters that get the booster pushrod modified for the proper stroke
[Re: DAYCLONA]
#1184281
02/23/12 12:19 AM
02/23/12 12:19 AM
Posts: 75,092 A Banana Republic near you.
JohnRR
I make both styles.
Good to know in case I end up putting the Hemi in the Bee and I don't want to waste a g note plus on a booster
[Re: DAYCLONA]
#1184282
02/23/12 09:12 AM
02/23/12 09:12 AM
Posts: 21,489 It's a dry heat
gtx6970
It's a dry heat
Correct. When I did this car my customer was not after 100% dead nuts appearence . He was after 'The look' and Cass's brackets along with the modified booster all is good on our end.
Everyting done and on the car and he is WAAAAAAYYYYYYY under the buy in price on a 'correct' Hemi booster setup and brackets
[Re: gtx6970]
#1184283
02/23/12 10:25 AM
02/23/12 10:25 AM
JohnRR
Bill who does the booster mod ?
[Re: JohnRR]
#1184284
02/23/12 10:30 AM
02/23/12 10:30 AM
gtx6970
It's a dry heat
Booster Dewey did mine.
I told him I had Cass's brackets and he modified the booster as needed.
It's on the car and every single piece fit and works perfect.
I can try to get some pictures later today if needed, as I have the car back in to fix some bugs. But it might be tomorrow as I have a funeral to attend this afternoon.
[Re: gtx6970]
#1184286
02/23/12 02:46 PM
02/23/12 02:46 PM
JohnRR
Thanks , no picture is needed at this point .
