Hemi valve cover grease pencil numbers #1183326
02/21/12 09:23 AM
02/21/12 09:23 AM
Charlotte, NC
Kowal Offline OP
Kowal  Offline OP
Charlotte, NC
I know this has been discussed before, but I haven't been able to find the thread.
On the front of the valve covers is the last couple digits of the part numbers (with auto or manual linkage) in white grease pencil on a Hemi, black on the rest.
What are the correct numbers for the front of a 68 Hemi with an automatic? Lynch Road car.
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
Re: Hemi valve cover grease pencil numbers [Re: Kowal] #1183327
02/21/12 11:35 PM
02/21/12 11:35 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
I believe the you are asking about the engine code numbers. I think they are listed on the fender tag and/or build sheet. The MyMopar site list 447 as the code for 1968 HEMI automatic but I would suggest you do some more research to confirm, I'm a rookie at this stuff.
Re: Hemi valve cover grease pencil numbers [Re: Ply72rr] #1183328
02/22/12 04:46 PM
02/22/12 04:46 PM
Charlotte, NC
Kowal Offline OP
Kowal  Offline OP
Charlotte, NC
Here is a pic I snapped of a recently restored Hemi in a 68 Dodge. An automatic.
I wasn't sure of this number, I have seen numbers on survivor Hemi's that were different.
Re: Hemi valve cover grease pencil numbers [Re: Kowal] #1183329
02/22/12 04:52 PM
02/22/12 04:52 PM
Charlotte, NC
Kowal Offline OP
Kowal  Offline OP
Charlotte, NC
Here is a survivor pic of a Hemi in a 69 Dodge, this one a 4 speed car. Picture is from a thread on the Lift Off Hood forum which I hope they don't mind that I borrowed for this.
Re: Hemi valve cover grease pencil numbers [Re: Ply72rr] #1183330
02/22/12 09:08 PM
02/22/12 09:08 PM
www.mmcdetroit.com
MMC Detroit Offline
MMC Detroit  Offline
www.mmcdetroit.com
Engine code from the broadcast sheet
MMC/ ICCA Detroit. The Motor City or where ever there is Mopars
Re: Hemi valve cover grease pencil numbers [Re: MMC Detroit] #1183331
02/23/12 12:33 AM
02/23/12 12:33 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I thought that the engine code was on the front of the pass vc, the tranny code was on the front of the driver vc, and the carb code was on top of the driver vc. All coded off the broadcast sheet. And those codes could very well vary from year to year.
Do I remember right?
Master, again and still
Re: Hemi valve cover grease pencil numbers [Re: Kowal] #1183332
02/23/12 01:29 AM
02/23/12 01:29 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Are you positive this car was/is a four speed?
(9)22 would be the engine assembly code for a 69 Hemi with automatic.
(9)21 would be the code for a four speed car.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: Hemi valve cover grease pencil numbers [Re: 69CoronetRT] #1183333
02/23/12 05:57 PM
02/23/12 05:57 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I'm curious about this as well for my 68 Hemi RR auto. I have a copy of a buddies 68 4 speed Hemi RR and his engine code is 733. (do not have mine...) I can't see the trans code since a rusty seat spring covered that block. So is 734 the code for 68 hemi Auto? And that code is displayed on the pass side valve cover?
Re: Hemi valve cover grease pencil numbers [Re: 68jim] #1183334
02/23/12 10:03 PM
02/23/12 10:03 PM
AZ.
696pack Offline
696pack  Offline
AZ.
I'm curious about this as well for my 68 Hemi RR auto. I have a copy of a buddies 68 4 speed Hemi RR and his engine code is 733. (do not have mine...) I can't see the trans code since a rusty seat spring covered that block . So is 734 the code for 68 hemi Auto? And that code is displayed on the pass side valve cover?
Take a no. 2 pencil eraser and ligthly erase the rust mark. It sometimes works where you can read the code under it. It works for the grease pencil marks too as the grease pencils has graphite in them which is what is in pencil lead.
Re: Hemi valve cover grease pencil numbers [Re: 69CoronetRT] #1183335
02/23/12 11:26 PM
02/23/12 11:26 PM
Charlotte, NC
Kowal Offline OP
Kowal  Offline OP
Charlotte, NC
. Checked, original owner had a second, automatic, car. Probably swapped valve covers.
Re: Hemi valve cover grease pencil numbers [Re: 696pack] #1183336
02/24/12 02:16 PM
02/24/12 02:16 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I appreciate the tip, however in this case my copy of his sheet is a scan...
So back to the topic - The engine numbers are on the driver side and not the passenger side? The posted picture showed a three digit number, my memory is not that great anymore but I seem to recall usually seeing just a two digit number there.
