I believe the you are asking about the engine code numbers. I think they are listed on the fender tag and/or build sheet. The MyMopar site list 447 as the code for 1968 HEMI automatic but I would suggest you do some more research to confirm, I'm a rookie at this stuff.
Engine code from the broadcast sheet
MMC/ ICCA Detroit. The Motor City or where ever there is Mopars
