Page 2 of 4 1 2 3 4
Re: does your street car run between 10.50's and 11.30's? [Re: justinp61] #1170794
02/02/12 11:58 PM
02/02/12 11:58 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
My Dart went 11.30@118 on its fouth pass In full street trim.
The combo is
408 SB with ported W2 heads, small solid roller cam, 9.8 to 1, victor intake with a Holley 950 Ulta HP.
904 trans with a Dynamic 9.5 inch converter that works great.
8 3/4 rear end with 3.73 gears.
The car weights 3360 with me in it.
In the last four months I have put 2200 miles on the car, including driving it to Vegas and back last november.
I also drive the car to work a fair amount, 24 mile round trip and I hope to do Dragweek with the car this fall.
Once the car is dialed in Iam hoping it runs 11 Teens.
Re: does your street car run between 10.50's and 11.30's? [Re: shoebox] #1170795
02/03/12 12:36 AM
02/03/12 12:36 AM
Alberta Canada
StrokerAspen Offline
Alberta Canada
man that aspen is a bad mofo! wow! labratt your stuffs looking killer btw great posts guys keep em coming
Thanks! I can't wait for the first launch without the 3.23's. As you can see in this video, it isn't too eventful now.
http://www.youtube.com/watch?v=8-PO1bCE3E0&feature=youtube_gdata_player
Labratt's X is going to look killer when it's done!
-Kenny
Re: does your street car run between 10.50's and 11.30's? [Re: Darryls-Demon] #1170796
02/03/12 12:43 AM
02/03/12 12:43 AM
Camillus N.Y
rollerfork Offline
rollerfork  Offline
Camillus N.Y
My combo is a 410 8.5 stock edelbrock heads 2 1/2 inch exhaust 4.10 dana 4-speed with a small hydrolic roller cam and a 750 CSU carb. Had a Paxton novi 1200 set up originally. Replaced that with a 2 stage edelbrock nos plate. cars best with the blower was 11.60 @ 116 mph. Best time with nos 10.44 @ 130. When i race it i do drive to the track and if nothing breaks i drive it home.So far so good. Car never gets above 170 degrees even on 90 degree days. PS love all the cars and trucks on this thread so far
Re: does your street car run between 10.50's and 11.30's? [Re: shoebox] #1170797
02/03/12 12:50 AM
02/03/12 12:50 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Yes it does, unfortunately.
Kidding
Ugly '69 GTX, Home/self built 400 based 451 with good machine work 10.75:1, 93 octane, Edelbrock RPM heads without any porting, Porter Racing heads .630 solid roller, self-cleaned up Victor 383 manifold, so-called 1000 cfm race demon, 2" super comps into homemade 3.5" X pipe, ultraflow oval mufflers, 9" converter, 4.10 Dana, 29" Hoosier DOT tires.
Car has alot of weird compromises like a working heater, the battery is still underhood and so on. For some reason I just never wanted to change any of that. My favorite time to run is when it's 50 degrees out and I run the heater often.
It's 11 flat at 123 for the time being, it should be 10.80s or so when I get the chassis set up a little better for drag racing.
I didn't do squat in 2011, was busy building a new shop but am thinking maybe this is the year (I say that every year and always come up with a new excuse).
Here is me and John For...I mean Randy B./Labratt back in 2010 doing our burnouts. I'm in the far lane and you can't see my car very well (Trust me, this is a good thing):
Click here
Here's me and Randy going after it. Once again you can't see my car particularly well. I think I went 11.09 and Randy went 11.20s on that pass? Timeslip got wet and blurry, can't read it anymore:
Another link, click here
There are more pics, but anyone who has seen my pile will tell you, it's nothing much to look at. Hope to get after the numerous cosmetic issues after I see a few 10 second passes.
Rich H.
Esse Quam Videri
Re: does your street car run between 10.50's and 11.30's? [Re: shoebox] #1170798
02/03/12 12:57 AM
02/03/12 12:57 AM
My Duster has ran between low 12s at a 2300 ft track to high nines at a 180 above sea level track depending on which motor and converter was in it. 446 C,I, 440 block, stock iron heads single four barrel went in the low 12s and high 11s., 452 C.i. 440 block with more cam and better heads went 11,30 to 11.40. 464 C.I. 440 block with Eddy RPM and a six pak went low 11s and high 10s on pupm gas 512 C.I. stroker 400 block went 10;70s with ported 906 heads and a six pak. Changed heads to a set of CNC ported Eddy RPM heads and increase the stroke (4.25 to 4.300) to make more compression(from 9,25 to 1 to 10.29 to 1), same cam, rods, pistons and six pak went 10:43. switch heads and intake to a set of Indy M.W port size SR with 76 CC, increased the comp. ratio to 10.79 to 1,and a Indy 400-3 intake and a Holley 1050 Dominator carb went 9.993 Car is a 1971 Duster that weighs 3450 lb with me in it, Oregon non ethanol 92 octane pump gas, Dana 60 now with 4:10 gears, T/A 8 inch race converter, ladder bars and coil overs, M/T 13.50x30x15 ET Street bias plys and 315x60x15 M/T ET Street Radials. This is my test baby and occasional street driver, lots of fun and a thrill to drive Opps, forgot the picture
Re: does your street car run between 10.50's and 11.30's? [Re: Cab_Burge] #1170799
02/03/12 01:20 AM
02/03/12 01:20 AM
Current Motor picture, 518 C.I. with Indy SR heads.
Re: does your street car run between 10.50's and 11.30's? [Re: Cab_Burge] #1170800
02/03/12 01:29 AM
02/03/12 01:29 AM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
Coronet has a 501 (400 block) Indy lil ez heads comp roller .704 with 268/276@.050,1050, Hooker super comps through 3.5inch Hooker Aero chambers with turn downs at the rear bumper,Dana 60 with 4.10 and 315 drag radials on pump gas ran 10.22@ 129. Weighed 3800 with me at the time.
Duster has a .020 360 with a .508 hydraulic,stock rocker arms on Edelbrock heads out of the box,air gap with a proform 850. TTi headers through 3 inch magnaflows with x pipe on a 275 drag radial,4.10 gear and pump gas ran an 11.77 @ 114.
Both cars have monoleaf cal tracs with 90/10 calvert shocks and batteries in the trunk.
The 501 is making its way into the Duster so hopefully it will be a 9.90 pump gas street car
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: does your street car run between 10.50's and 11.30's? [Re: Darryls-Demon] #1170801
02/03/12 01:44 AM
02/03/12 01:44 AM
Arizona
Chris'sBarracuda Offline
Arizona
My Dart went [Email]11.30@118[/Email] on its fouth pass In full street trim.
The combo is
I've seen Darryl's car in person, and it is perfect for Drag Week.. Really nice car.
Chris..
Re: does your street car run between 10.50's and 11.30's? [Re: Chris'sBarracuda] #1170802
02/03/12 02:55 AM
02/03/12 02:55 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I forgot to mention that my suspension is all stock other then 3400 lb SS springs in the rear with the long C-body shocks. The front is all stock but with comp 90/10 shocks. Ron
Re: does your street car run between 10.50's and 11.30's? [Re: earthmover] #1170803
02/03/12 06:36 AM
02/03/12 06:36 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
you have any pics of the car where you can see the top of the car..like the black part..my dart is about to be painted some day and that may work
How's this...
Re: does your street car run between 10.50's and 11.30's? [Re: BigBlockMopar] #1170804
02/03/12 07:40 AM
02/03/12 07:40 AM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
Dig that coool Vista Cruiser!!
Re: does your street car run between 10.50's and 11.30's? [Re: bobs66440] #1170805
02/03/12 10:04 AM
02/03/12 10:04 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
My Barracuda runs high 10's all summer and takes me to the grocery store every weekend. 410 stroker, 10.8:1, pump gas, ported Edelbrocks, small solid roller 248/254 duration with.576/.582 lift, 750dp, Victor, 727, 8" converter, 4.10 gear, 3200#'s.
My best times actually came during Monster Mopar Weekend last year when I was trying to slow the car down to make the 11.0 index class...I added all the extra weight I had, let off WAY early and went 10.88....I think there are 10.70's in my future.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: does your street car run between 10.50's and 11.30's? [Re: FlyFish] #1170806
02/03/12 10:13 AM
02/03/12 10:13 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
mowder
I'm like Ron stock Mopar suspension, I have XHD springs, 318 t-bars and $20 Gas-matic shocks in all 4 corners.
Re: does your street car run between 10.50's and 11.30's? [Re: FlyFish] #1170807
02/03/12 10:58 AM
02/03/12 10:58 AM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
My charger runs consistant 10.60's through the mufflers on dot's. 499 RB all stock suspension mild roller cam 1050 dominator stage VI heads. I just got the title all straightened out so its gonna see some street miles this year.
Uploaded with ImageShack.us
67' charger 499 RB 10.57 at 127
Re: does your street car run between 10.50's and 11.30's? [Re: dragram440] #1170808
02/03/12 11:40 AM
02/03/12 11:40 AM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
MAN! THESE POSTS ARE AWESOME! super cool cars! yall small block A body guys are killin me lol this thread is turning out like i wanted.
74 dart sport 440 www.Csucarbs.com
Re: does your street car run between 10.50's and 11.30's? [Re: shoebox] #1170809
02/03/12 12:56 PM
02/03/12 12:56 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
Yeah Some awesome rides for sure. Some Stealth projects out there
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: does your street car run between 10.50's and 11.30's? [Re: Kam*Kuda] #1170810
02/03/12 01:06 PM
02/03/12 01:06 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
Mine used to run 10.40 at 129.1 mph at 3700# w/ a .030" over 440, stock crank, H beam rods, Ross dome pistons
Out of the box unported Indy SR heads
268 at fifty solid roller, .660"/.620" lift
Team G w/ a 1050 dominator
9" 5k stall, 4.10 gear
Too much compression for pump gas, still drove it on the street all the time though.
Before that it ran 11.40 at 117.4 mph at 3700# w/ a basic 509/292 cammed 440 w/ ported 915 heads, Performer RPM w/ an 830 Holley, 3500 stall, 4.10 gear, 3" full exhaust, etc. Same combo went 10.60s w/ a small shot of nitrous.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: does your street car run between 10.50's and 11.30's? [Re: shoebox] #1170811
02/03/12 01:09 PM
02/03/12 01:09 PM
Backwater, PA
bwdst6 Offline
Bob George Racing #1 Fan
bwdst6  Offline
Backwater, PA
Sure a lot of pictures of cars with slicks on them.
This post is available in double vision where drunk.
Re: does your street car run between 10.50's and 11.30's? [Re: bwdst6] #1170812
02/03/12 02:00 PM
02/03/12 02:00 PM
Alberta Canada
Alberta Canada
What's wrong with slicks? I have pictures with radials too.
275/60R15
295/65R15.
Re: does your street car run between 10.50's and 11.30's? [Re: StrokerAspen] #1170813
02/03/12 02:11 PM
02/03/12 02:11 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I always drive on my Hoosier radial slicks. They handle pretty good on the street. Ron
Page 2 of 4 1 2 3 4
