Re: does your street car run between 10.50's and 11.30's?
[Re: justinp61]
#1170794
02/02/12 11:58 PM
02/02/12 11:58 PM
Posts: 795 Glendale Az
Darryls-Demon
Glendale Az
My Dart went 11.30@118 on its fouth pass In full street trim. The combo is 408 SB with ported W2 heads, small solid roller cam, 9.8 to 1, victor intake with a Holley 950 Ulta HP. 904 trans with a Dynamic 9.5 inch converter that works great. 8 3/4 rear end with 3.73 gears. The car weights 3360 with me in it. In the last four months I have put 2200 miles on the car, including driving it to Vegas and back last november. I also drive the car to work a fair amount, 24 mile round trip and I hope to do Dragweek with the car this fall. Once the car is dialed in Iam hoping it runs 11 Teens.
[Re: shoebox]
#1170797
02/03/12 12:50 AM
02/03/12 12:50 AM
Posts: 17,904 S.E. Michigan
ZIPPY
S.E. Michigan
Yes it does, unfortunately. Kidding Ugly '69 GTX, Home/self built 400 based 451 with good machine work 10.75:1, 93 octane, Edelbrock RPM heads without any porting, Porter Racing heads .630 solid roller, self-cleaned up Victor 383 manifold, so-called 1000 cfm race demon, 2" super comps into homemade 3.5" X pipe, ultraflow oval mufflers, 9" converter, 4.10 Dana, 29" Hoosier DOT tires. Car has alot of weird compromises like a working heater, the battery is still underhood and so on. For some reason I just never wanted to change any of that. My favorite time to run is when it's 50 degrees out and I run the heater often. It's 11 flat at 123 for the time being, it should be 10.80s or so when I get the chassis set up a little better for drag racing. I didn't do squat in 2011, was busy building a new shop but am thinking maybe this is the year (I say that every year and always come up with a new excuse). Here is me and John For...I mean Randy B./Labratt back in 2010 doing our burnouts. I'm in the far lane and you can't see my car very well (Trust me, this is a good thing): Click here Here's me and Randy going after it. Once again you can't see my car particularly well. I think I went 11.09 and Randy went 11.20s on that pass? Timeslip got wet and blurry, can't read it anymore: Another link, click here There are more pics, but anyone who has seen my pile will tell you, it's nothing much to look at. Hope to get after the numerous cosmetic issues after I see a few 10 second passes.
Rich H.
Esse Quam Videri
[Re: shoebox]
#1170798
02/03/12 12:57 AM
02/03/12 12:57 AM
Posts: 43,260 Bend,OR USA
Cab_Burge
My Duster has ran between low 12s at a 2300 ft track to high nines at a 180 above sea level track depending on which motor and converter was in it. 446 C,I, 440 block, stock iron heads single four barrel went in the low 12s and high 11s., 452 C.i. 440 block with more cam and better heads went 11,30 to 11.40. 464 C.I. 440 block with Eddy RPM and a six pak went low 11s and high 10s on pupm gas 512 C.I. stroker 400 block went 10;70s with ported 906 heads and a six pak. Changed heads to a set of CNC ported Eddy RPM heads and increase the stroke (4.25 to 4.300) to make more compression(from 9,25 to 1 to 10.29 to 1), same cam, rods, pistons and six pak went 10:43. switch heads and intake to a set of Indy M.W port size SR with 76 CC, increased the comp. ratio to 10.79 to 1,and a Indy 400-3 intake and a Holley 1050 Dominator carb went 9.993 Car is a 1971 Duster that weighs 3450 lb with me in it, Oregon non ethanol 92 octane pump gas, Dana 60 now with 4:10 gears, T/A 8 inch race converter, ladder bars and coil overs, M/T 13.50x30x15 ET Street bias plys and 315x60x15 M/T ET Street Radials. This is my test baby and occasional street driver, lots of fun and a thrill to drive Opps, forgot the picture
[Re: Cab_Burge]
#1170799
02/03/12 01:20 AM
02/03/12 01:20 AM
Cab_Burge
Current Motor picture, 518 C.I. with Indy SR heads.
[Re: Cab_Burge]
#1170800
02/03/12 01:29 AM
02/03/12 01:29 AM
Posts: 902 Mopar Lane,Mississippi
67HEMI
Coronet has a 501 (400 block) Indy lil ez heads comp roller .704 with 268/276@.050,1050, Hooker super comps through 3.5inch Hooker Aero chambers with turn downs at the rear bumper,Dana 60 with 4.10 and 315 drag radials on pump gas ran 10.22@ 129. Weighed 3800 with me at the time. Duster has a .020 360 with a .508 hydraulic,stock rocker arms on Edelbrock heads out of the box,air gap with a proform 850. TTi headers through 3 inch magnaflows with x pipe on a 275 drag radial,4.10 gear and pump gas ran an 11.77 @ 114. Both cars have monoleaf cal tracs with 90/10 calvert shocks and batteries in the trunk. The 501 is making its way into the Duster so hopefully it will be a 9.90 pump gas street car
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction)
'69 Chrysler 300 Convertible 375 HP 440
'71 Plymouth Duster 360 W/EFI (Wife's Ride)
'12 Ram MegaCab Dually 6.7 Cummins
[Re: Darryls-Demon]
#1170801
02/03/12 01:44 AM
02/03/12 01:44 AM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
My Dart went [Email]11.30@118[/Email] on its fouth pass In full street trim.
I've seen Darryl's car in person, and it is perfect for Drag Week.. Really nice car.
Chris..
[Re: earthmover]
#1170803
02/03/12 06:36 AM
02/03/12 06:36 AM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
you have any pics of the car where you can see the top of the car..like the black part..my dart is about to be painted some day and that may work
How's this...
[Re: bobs66440]
#1170805
02/03/12 10:04 AM
02/03/12 10:04 AM
Posts: 1,178 Indy
FlyFish
Indy
My Barracuda runs high 10's all summer and takes me to the grocery store every weekend. 410 stroker, 10.8:1, pump gas, ported Edelbrocks, small solid roller 248/254 duration with.576/.582 lift, 750dp, Victor, 727, 8" converter, 4.10 gear, 3200#'s. My best times actually came during Monster Mopar Weekend last year when I was trying to slow the car down to make the 11.0 index class...I added all the extra weight I had, let off WAY early and went 10.88....I think there are 10.70's in my future.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: Kam*Kuda]
#1170810
02/03/12 01:06 PM
02/03/12 01:06 PM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
Mine used to run 10.40 at 129.1 mph at 3700# w/ a .030" over 440, stock crank, H beam rods, Ross dome pistons Out of the box unported Indy SR heads 268 at fifty solid roller, .660"/.620" lift Team G w/ a 1050 dominator 9" 5k stall, 4.10 gear Too much compression for pump gas, still drove it on the street all the time though.
Before that it ran 11.40 at 117.4 mph at 3700# w/ a basic 509/292 cammed 440 w/ ported 915 heads, Performer RPM w/ an 830 Holley, 3500 stall, 4.10 gear, 3" full exhaust, etc. Same combo went 10.60s w/ a small shot of nitrous.
[Re: shoebox]
#1170811
02/03/12 01:09 PM
02/03/12 01:09 PM
Posts: 970 Backwater, PA
bwdst6
Bob George Racing #1 Fan
Backwater, PA
Sure a lot of pictures of cars with slicks on them.
This post is available in double vision where drunk.
[Re: bwdst6]
#1170812
02/03/12 02:00 PM
02/03/12 02:00 PM
Posts: 1,600 Alberta Canada
StrokerAspen
Alberta Canada
What's wrong with slicks? I have pictures with radials too. 275/60R15 295/65R15.
