What spark plugs do you like? #1169577
01/31/12 09:00 PM
01/31/12 09:00 PM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
I need to change the plugs in my 440, low compression engine. Holley 750 DP Carb. What plugs do you like for this application?
Oh, stock electronic ignition.
Re: What spark plugs do you like? [Re: lahatte] #1169578
01/31/12 09:06 PM
01/31/12 09:06 PM
Central TX
roe Offline
roe  Offline
Central TX
I have Autolite Platinums in my smallblock with PertronixII ignition. I also run the bosch platinums. I think Im going to try the Autolite Double Platinums next and see how I like em. Ive never had anyproblems with the Autolites
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: What spark plugs do you like? [Re: roe] #1169579
01/31/12 09:08 PM
01/31/12 09:08 PM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
Ultimately, my engine is developing a miss. Since it's liely the factory build, it could be due to a failing lifter. But I thought I would change the plugs and wires first.
Re: What spark plugs do you like? [Re: lahatte] #1169580
01/31/12 09:48 PM
01/31/12 09:48 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I like NGK plugs, most parts stores sell them.
Might want to pull your valve covers and make sure that you don't have a cam lobe going flat. By pulling of the coil wire you can crank the engine and watch each valve go up and down to eliminate that possibility. I think it is hard to do a compression test on a 440 with headers, a compression test would be best. Good luck with it.
Re: What spark plugs do you like? [Re: Challenger 1] #1169581
01/31/12 09:50 PM
01/31/12 09:50 PM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
This one has the stock manifolds, but a compression test is still a bit of a pain.
Re: What spark plugs do you like? [Re: lahatte] #1169582
01/31/12 10:41 PM
01/31/12 10:41 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
NGK or Champions. Autolite is Chinese now. Bosch and any platinum plug is a bandaid unless the system was designed to run them.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: What spark plugs do you like? [Re: lahatte] #1169583
01/31/12 10:46 PM
01/31/12 10:46 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Stock heads RJ12YC champions
Re: What spark plugs do you like? [Re: Dodgem] #1169584
02/01/12 12:38 AM
02/01/12 12:38 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Been using Autolites since the late 70's. Ron
Re: What spark plugs do you like? [Re: lahatte] #1169585
02/01/12 12:58 AM
02/01/12 12:58 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Your best off sticking with Autolites using the stock electronic ignition
I myself run Bosch Platinum single or double eletrode on my cars, but they are Petronix equipped
Re: What spark plugs do you like? [Re: lahatte] #1169586
02/01/12 12:59 AM
02/01/12 12:59 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
For a standard (non-platnum) plug, I have been using NGK brand and I have not had any spark plug related problems. For the newer cars where spark plug changes are 60,000 miles or more I have been using the Autolite Double Platnum plugs. I never really compared different brands of double platnum plugs, so I'm not sure of whos brand is good or bad?
Re: What spark plugs do you like? [Re: 451Mopar] #1169587
02/01/12 08:32 AM
02/01/12 08:32 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I ran Autolites since the 60s.Changed to NGKs.Better idle and seems to have a bit more go also.Just put a set in the wifes PT also.Ran Champions and Autolite platinums and would develop an intermitten miss.NGKs so far no miss.Rocky
Chrysler Firepower
Re: What spark plugs do you like? [Re: DAYCLONA] #1169588
02/01/12 09:36 AM
02/01/12 09:36 AM
Rug_Trucker Offline
Rug_Trucker  Offline
You're joking, right?
Why run a double?
Re: What spark plugs do you like? [Re: Rug_Trucker] #1169589
02/01/12 10:08 AM
02/01/12 10:08 AM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
NGK.
Re: What spark plugs do you like? [Re: DennisH ] #1169590
02/01/12 10:11 AM
02/01/12 10:11 AM
ill
dennismopar73 Offline
ill
N G K, CHAMPION!
Re: What spark plugs do you like? [Re: dennismopar73] #1169591
02/01/12 10:29 AM
02/01/12 10:29 AM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
I run Champs and Mexican Autolites.
Re: What spark plugs do you like? [Re: ireland383] #1169592
02/01/12 10:49 AM
02/01/12 10:49 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Champion , or NGK for Mopars, Autolites, or AC for GM, and motocraft for the ferds, also NGK for Ferds.
Kasey
Re: What spark plugs do you like? [Re: Moparnut426] #1169593
02/01/12 11:19 AM
02/01/12 11:19 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Always used Champion on my mopars.
I have mechanical Aptitude.
I can screw up anything.
Re: What spark plugs do you like? [Re: lahatte] #1169594
02/01/12 11:56 AM
02/01/12 11:56 AM
Cincinnati, Ohio
chargincharles Offline
Cincinnati, Ohio
Mopars use Champion.
Period.
Every Mopar I have ever owned (or currently own) ran better using them.
Old Mopars- all my Chargers, Trucks and current 5th ave- standard copper Champions as called for by the service manual.
Newer Mopars- my SRT, Caliber, Stratus- same as above. But I did use Champion Platinum in the SRT and Caliber. Stratus has the good ol' copper ones.
CC.
Re: What spark plugs do you like? [Re: chargincharles] #1169595
02/01/12 12:00 PM
02/01/12 12:00 PM
Cincinnati, Ohio
Cincinnati, Ohio
Period.
CC.
The new champions suck,imo they are not the same plug as they were years ago. Use NGK they are worlds better, I'm sure.
Re: What spark plugs do you like? [Re: Challenger 1] #1169596
02/01/12 10:18 PM
02/01/12 10:18 PM
I use Autolites in a DD tho as said prob outsourced & I'm sure there's a better plug avail for my "good" car. No probs so far
