What spark plugs do you like?
#1169577
01/31/12 09:00 PM
01/31/12 09:00 PM
Posts: 392 Mississippi
lahatte
Mississippi
I need to change the plugs in my 440, low compression engine. Holley 750 DP Carb. What plugs do you like for this application?
Oh, stock electronic ignition.
Re: What spark plugs do you like?
[Re: lahatte]
#1169578
01/31/12 09:06 PM
01/31/12 09:06 PM
Posts: 3,344 Central TX
roe
Central TX
I have Autolite Platinums in my smallblock with PertronixII ignition. I also run the bosch platinums. I think Im going to try the Autolite Double Platinums next and see how I like em. Ive never had anyproblems with the Autolites
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
[Re: lahatte]
#1169582
01/31/12 10:41 PM
01/31/12 10:41 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
NGK or Champions. Autolite is Chinese now. Bosch and any platinum plug is a bandaid unless the system was designed to run them.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: lahatte]
#1169585
02/01/12 12:58 AM
02/01/12 12:58 AM
Posts: 18,160 Mass
DAYCLONA
Mass
Your best off sticking with Autolites using the stock electronic ignition
I myself run Bosch Platinum single or double eletrode on my cars, but they are Petronix equipped
[Re: 451Mopar]
#1169587
02/01/12 08:32 AM
02/01/12 08:32 AM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
I ran Autolites since the 60s.Changed to NGKs.Better idle and seems to have a bit more go also.Just put a set in the wifes PT also.Ran Champions and Autolite platinums and would develop an intermitten miss.NGKs so far no miss.Rocky
Chrysler Firepower
[Re: DennisH ]
#1169590
02/01/12 10:11 AM
02/01/12 10:11 AM
Posts: 2,177 ill
dennismopar73
ill
[Re: chargincharles]
#1169595
02/01/12 12:00 PM
02/01/12 12:00 PM
Challenger 1
Cincinnati, Ohio
Mopars use Champion. Period.
Every Mopar I have ever owned (or currently own) ran better using them.
Old Mopars- all my Chargers, Trucks and current 5th ave- standard copper Champions as called for by the service manual. Newer Mopars- my SRT, Caliber, Stratus- same as above. But I did use Champion Platinum in the SRT and Caliber. Stratus has the good ol' copper ones.
CC.
The new champions suck,imo they are not the same plug as they were years ago. Use NGK they are worlds better, I'm sure.
[Re: Challenger 1]
#1169596
02/01/12 10:18 PM
02/01/12 10:18 PM
RapidRobert
I use Autolites in a DD tho as said prob outsourced & I'm sure there's a better plug avail for my "good" car. No probs so far
