69 and 70 B body K frames the same? #1159061
01/17/12 01:48 AM
01/17/12 01:48 AM
Houston Texas
PAINT IT BLACK Offline OP
Got a CHIP on my shoulder
Houston Texas
My wheels are turning. Life changes. I'm transitioning. I Need to know 'in case'.
Re: 69 and 70 B body K frames the same? [Re: PAINT IT BLACK] #1159062
01/17/12 09:41 AM
01/17/12 09:41 AM
Houston, Tx
hemi68charger Offline
Houston, Tx
Morning Steve...
No, They are different. Off the top of my head here in the office without looking at my reference pictures at home, I know the mounting points for the sway bar are different, that's one thing. I'm sure there are other subtle difference, but can't remember.
Re: 69 and 70 B body K frames the same? [Re: hemi68charger] #1159063
01/17/12 11:56 AM
01/17/12 11:56 AM
Houston Texas
Houston Texas
Thanks mang....
Re: 69 and 70 B body K frames the same? [Re: PAINT IT BLACK] #1159064
01/17/12 12:15 PM
01/17/12 12:15 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
69 left and 70 on the right.
Also the angel of the steering box mount is like 4* difference.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 69 and 70 B body K frames the same? [Re: moparmarks] #1159065
01/17/12 01:25 PM
01/17/12 01:25 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
First that I heard that the angle of the steering box is different on the B-body, thought that was on the E-body or was that the A-body....anyway I thought the later '69 B-body K-frame (i.e. A12) were the same except the holes for the swaybar were drilled or not drilled depending on '69 or '70. The '69 swaybar runs in front of the K-frame and the '70 runs through it.
Re: 69 and 70 B body K frames the same? [Re: A12] #1159066
01/17/12 01:40 PM
01/17/12 01:40 PM
moparmarks Offline
moparmarks  Offline
First that I heard that the angle of the steering box is different on the B-body, thought that was on the E-body or was the A-body....anyway I thought the later '69 B-body K-frame were the same except the holes for the swaybar were drilled or not drilled depending on '69 or '70. The '69 swaybar runs in front of the K-frame and the '70 runs through it.
Excuss me. The 70B frame is the same as the 70-4E and 71-2B except the box angel is different. The 69 and 70 B frames share the same box angel. Sway bar is the difference making the 70B frame a 1 year 1 model part.
Sorry about that
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 69 and 70 B body K frames the same? [Re: A12] #1159067
01/17/12 01:41 PM
01/17/12 01:41 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
'69 A12 K-frame ID which may help with the '70 K-frame question?
MikeR
Re: 69 and 70 B body K frames the same? [Re: moparmarks] #1159068
01/17/12 01:49 PM
01/17/12 01:49 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Sorry about that
.............but you could still drill the holes for either a '69 or '70 swaybar and use a late production '69 on a '70 B-body K-frame or vice versa
MikeR
