Re: 69 and 70 B body K frames the same?
[Re: PAINT IT BLACK]
#1159062
01/17/12 09:41 AM
01/17/12 09:41 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Morning Steve... No, They are different. Off the top of my head here in the office without looking at my reference pictures at home, I know the mounting points for the sway bar are different, that's one thing. I'm sure there are other subtle difference, but can't remember.
[Re: moparmarks]
#1159065
01/17/12 01:25 PM
01/17/12 01:25 PM
Posts: 21,525 N.E. OHIO, USA
A12
N.E. OHIO, USA
69 left and 70 on the right. Also the angel of the steering box mount is like 4* difference.
First that I heard that the angle of the steering box is different on the B-body, thought that was on the E-body or was that the A-body....anyway I thought the later '69 B-body K-frame (i.e. A12) were the same except the holes for the swaybar were drilled or not drilled depending on '69 or '70. The '69 swaybar runs in front of the K-frame and the '70 runs through it.
[Re: A12]
#1159066
01/17/12 01:40 PM
01/17/12 01:40 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
First that I heard that the angle of the steering box is different on the B-body, thought that was on the E-body or was the A-body....anyway I thought the later '69 B-body K-frame were the same except the holes for the swaybar were drilled or not drilled depending on '69 or '70. The '69 swaybar runs in front of the K-frame and the '70 runs through it.
Excuss me. The 70B frame is the same as the 70-4E and 71-2B except the box angel is different. The 69 and 70 B frames share the same box angel. Sway bar is the difference making the 70B frame a 1 year 1 model part. Sorry about that
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#1159068
01/17/12 01:49 PM
01/17/12 01:49 PM
A12
N.E. OHIO, USA
.............but you could still drill the holes for either a '69 or '70 swaybar and use a late production '69 on a '70 B-body K-frame or vice versa
MikeR
