oliver rods and crower cranks #1158872
01/16/12 09:41 PM
01/16/12 09:41 PM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
does any body have in input on these guys
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: oliver rods and crower cranks [Re: WHITEDART] #1158873
01/16/12 10:13 PM
01/16/12 10:13 PM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
that red duster you seen at fontana with the 340 runs oliver rods. nice pieces, but some will say they dont like them. i had heard that the grain direction on the caps run the wrong way. but i can't back that speculation up. i've learned that you should save your lunch money and buy the ones you can't afford. you'll be money ahead.
Re: oliver rods and crower cranks [Re: WHITEDART] #1158874
01/16/12 10:54 PM
01/16/12 10:54 PM
AndyF Offline
AndyF  Offline
Oliver builds nice rods. Callies would be a good place to look for a higher end crankshaft.
Re: oliver rods and crower cranks [Re: WHITEDART] #1158875
01/17/12 12:41 AM
01/17/12 12:41 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I have a crower crnk and their best rod in mine. they cut the mopar BB cranks from their chevy forgings.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: oliver rods and crower cranks [Re: Deepockets] #1158876
01/17/12 12:57 AM
01/17/12 12:57 AM
bean town ....Ca
W
W
bean town ....Ca
my 340 wont be as fast as yours but i hope it will run as good as your other car
Re: oliver rods and crower cranks [Re: AndyF] #1158877
01/17/12 01:00 AM
01/17/12 01:00 AM
bean town ....Ca
W
W
bean town ....Ca
thank guys for the help
Re: oliver rods and crower cranks [Re: WHITEDART] #1158878
01/17/12 01:07 AM
01/17/12 01:07 AM
lower left, ca.
hookNgone Offline
hookNgone  Offline
lower left, ca.
That stuff is junk...do yourself a favor and get some Cat rods and a custom twisted forged rpm crank.
Re: oliver rods and crower cranks [Re: AndyF] #1158879
01/17/12 01:14 AM
01/17/12 01:14 AM
lower left, ca.
hookNgone Offline
hookNgone  Offline
lower left, ca.
Callies stuff is great until the snout decides to break off and launch a balancer through the hood. Well at least the alternator saved it from going through hood.
Re: oliver rods and crower cranks [Re: hookNgone] #1158880
01/17/12 01:31 AM
01/17/12 01:31 AM
ONTARIO,CANADA
604 Hemi GTX Offline
ONTARIO,CANADA
Did you figure out why it broke? Bad balancer, wrong balancer?
Kevin
Re: oliver rods and crower cranks [Re: 604 Hemi GTX] #1158881
01/17/12 01:39 AM
01/17/12 01:39 AM
lower left, ca.
hookNgone Offline
hookNgone  Offline
lower left, ca.
Kevin
Yes, bad steel forging of foreign materials. BTW, very common problem. Balance job was good, no sign of detonation on main bearings or rod bearings, lower belt crank pulley had enough chamfer to seat against front counterweight.
Re: oliver rods and crower cranks [Re: hookNgone] #1158882
01/17/12 01:42 AM
01/17/12 01:42 AM
Delray beach, Florida
P
Performance Only Offline
P
Kevin
what type of application was that in?
machine shop owner and engine builder
Re: oliver rods and crower cranks [Re: Performance Only] #1158883
01/17/12 02:02 AM
01/17/12 02:02 AM
lower left, ca.
hookNgone Offline
hookNgone  Offline
lower left, ca.
sbf 3.250" stroke N/A drag car
Re: oliver rods and crower cranks [Re: WHITEDART] #1158884
01/17/12 04:38 AM
01/17/12 04:38 AM
I had problems with one rod cap on the only set of Oliver steel billet rods that I bougt and used, also had problems the ARP L19 rod bolts they sent with them The one rod problem was that the bearing retaining tang in the rod was not machine correctly for the rod bearing tab to fit into properly, I was very lucky to catch it Oliver paid for the overnight Fed Ex and corrected it at thier expence but at $150.00 each I expect them to be perfect to start with The rod bolt problem was that they mixed up the bolts from two different batches and there was 25 lbs difference in torque to get them to stretch the same
Crower cranks are outstanding according to everyone I know(all three racers ) that have used them, they are on the high end of the market, just like Bryant, LA Billet and the other good company in CO, Winberg Which type crank are you wanting to use, forged or billet? Either way there is usually a two to twelve week waiting period from time of the order to delivery
Re: oliver rods and crower cranks [Re: WHITEDART] #1158885
01/17/12 09:08 AM
01/17/12 09:08 AM
Tucson AZ.
RADAMX Offline
RADAMX  Offline
Tucson AZ.
I use there billet 6 inch SB chevy rod in my rambler.
never seen any problem. 8,000 rpm and 400 hp nitrous
so far so good
Re: oliver rods and crower cranks [Re: RADAMX] #1158886
01/17/12 04:27 PM
01/17/12 04:27 PM
dogdays Offline
dogdays  Offline
A friend's Parabolic Billet rods went 8000+ rpm on a 3.75" stroke crank in my friend's stroker sbc for a couple of years before he built a bigger motor. They looked like jewels out of the box.
R.
Re: oliver rods and crower cranks [Re: Cab_Burge] #1158887
01/17/12 09:06 PM
01/17/12 09:06 PM
bean town ....Ca
W
W
bean town ....Ca
i bought a 4in billet for my small block they said 14 weeks. about 15 weeks ago so here i am waitin hope it is worth the wait
Re: oliver rods and crower cranks [Re: WHITEDART] #1158888
01/18/12 10:41 AM
01/18/12 10:41 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I researched most of the higher end rods when putting my last build plan together, Lentz, Oliver, Manly, Carillo, etc. Frankly they are all high end rods with great reputations, I can't say I heard of any real inherent problems with any of them. I doubt you would go wrong choosing any one of the lot but I ended up going with a custom Scat Lightweight 4.125 crank and Carillo rods (426 SB build). Turned out very nice, the rods were a very nice piece.
Re: oliver rods and crower cranks [Re: WHITEDART] #1158889
01/18/12 10:44 AM
01/18/12 10:44 AM
an8sec70cuda Offline
I have Oliver billet steel rods in my hemi...VERY nice. They were perfect out of the box.
I've never heard anything bad about Oliver or Crower parts.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: oliver rods and crower cranks [Re: an8sec70cuda] #1158890
01/18/12 04:59 PM
01/18/12 04:59 PM
Escondido, CA
kick_the_reverb Offline
Escondido, CA
Username 40Ford has experience with the high end rods in circle track situations, maybe PM him or look up old posts by him.
Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto
Finally - disc brakes on the front.
In the plans - rear disc brakes, B&M 250 blower
Re: oliver rods and crower cranks [Re: hookNgone] #1158891
01/19/12 10:04 AM
01/19/12 10:04 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
I have heard the same thing from few engine builders.
You won't find a better rod than Oliver. For a crankshaft I went Bryant. I didn't want anything bad to happen to my Hemi.
