Re: oliver rods and crower cranks
[Re: WHITEDART]
#1158875
01/17/12 12:41 AM
01/17/12 12:41 AM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
I have a crower crnk and their best rod in mine. they cut the mopar BB cranks from their chevy forgings.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: WHITEDART]
#1158878
01/17/12 01:07 AM
01/17/12 01:07 AM
Posts: 25 lower left, ca.
hookNgone
lower left, ca.
does any body have in input on these guys
That stuff is junk...do yourself a favor and get some Cat rods and a custom twisted forged rpm crank.
[Re: AndyF]
#1158879
01/17/12 01:14 AM
01/17/12 01:14 AM
hookNgone
lower left, ca.
Oliver builds nice rods. Callies would be a good place to look for a higher end crankshaft.
Callies stuff is great until the snout decides to break off and launch a balancer through the hood. Well at least the alternator saved it from going through hood.
[Re: hookNgone]
#1158880
01/17/12 01:31 AM
01/17/12 01:31 AM
Posts: 501 ONTARIO,CANADA
604 Hemi GTX
ONTARIO,CANADA
Did you figure out why it broke? Bad balancer, wrong balancer? Kevin
[Re: 604 Hemi GTX]
#1158881
01/17/12 01:39 AM
01/17/12 01:39 AM
hookNgone
lower left, ca.
Yes, bad steel forging of foreign materials. BTW, very common problem. Balance job was good, no sign of detonation on main bearings or rod bearings, lower belt crank pulley had enough chamfer to seat against front counterweight.
[Re: WHITEDART]
#1158884
01/17/12 04:38 AM
01/17/12 04:38 AM
Posts: 43,237 Bend,OR USA
Cab_Burge
I had problems with one rod cap on the only set of Oliver steel billet rods that I bougt and used, also had problems the ARP L19 rod bolts they sent with them The one rod problem was that the bearing retaining tang in the rod was not machine correctly for the rod bearing tab to fit into properly, I was very lucky to catch it Oliver paid for the overnight Fed Ex and corrected it at thier expence but at $150.00 each I expect them to be perfect to start with The rod bolt problem was that they mixed up the bolts from two different batches and there was 25 lbs difference in torque to get them to stretch the same Crower cranks are outstanding according to everyone I know(all three racers ) that have used them, they are on the high end of the market, just like Bryant, LA Billet and the other good company in CO, Winberg Which type crank are you wanting to use, forged or billet? Either way there is usually a two to twelve week waiting period from time of the order to delivery
[Re: WHITEDART]
#1158885
01/17/12 09:08 AM
01/17/12 09:08 AM
Posts: 235 Tucson AZ.
RADAMX
Tucson AZ.
I use there billet 6 inch SB chevy rod in my rambler. never seen any problem. 8,000 rpm and 400 hp nitrous so far so good
[Re: WHITEDART]
#1158889
01/18/12 10:44 AM
01/18/12 10:44 AM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
I have Oliver billet steel rods in my hemi...VERY nice. They were perfect out of the box. I've never heard anything bad about Oliver or Crower parts.
[Re: an8sec70cuda]
#1158890
01/18/12 04:59 PM
01/18/12 04:59 PM
Posts: 576 Escondido, CA
kick_the_reverb
Escondido, CA
Username 40Ford has experience with the high end rods in circle track situations, maybe PM him or look up old posts by him.
Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto Finally - disc brakes on the front. In the plans - rear disc brakes, B&M 250 blower
[Re: hookNgone]
#1158891
01/19/12 10:04 AM
01/19/12 10:04 AM
Posts: 3,619 Norwich CT USA
Defbob
Norwich CT USA
I have heard the same thing from few engine builders.
You won't find a better rod than Oliver. For a crankshaft I went Bryant. I didn't want anything bad to happen to my Hemi.
