Dip stick tube hight 340 #1158739
01/16/12 05:51 PM
01/16/12 05:51 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
I ordered a new dip stick and tube from Mancini racing. The tube is 12 inches long the one that came out is 8 inches long. I went to the garage and measured the one in my dart it is also 8 inches. Mancini says they sell tons and nobody complains he swears its correct for a 340. Has anybody run into this or do they make different length tubes and sticks for small blocks? whats in your small block 8 or 12 inch(insert joke here)tube.
Re: Dip stick tube hight 340 [Re: 340swing] #1158740
01/16/12 11:17 PM
01/16/12 11:17 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
Does anybody have a 340 dip stick tube out. If you could measure it from end to end so I could cut the new one to fit. Thanks
Re: Dip stick tube hight 340 [Re: 340swing] #1158741
01/17/12 01:59 AM
01/17/12 01:59 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I know my original numbers matching 340 has the short dip stick tube/stick like you describe. I run the longer Mancini tube/stick in my stroker. I could not find the shorter tube/stick like the original. You could cut down the longer tube if you have the shorter stick. If not I am sure a shorter stick could be located they don't tend to go back.
Re: Dip stick tube hight 340 [Re: 69Cuda340S] #1158742
01/17/12 08:43 AM
01/17/12 08:43 AM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
Bill, thanks for the reply. I need a measurement of the original short tube if anybody has one out. My original one was damaged and i'm not sure of the length. It appears to be around 8 inches. I can cut the new one and use the old stick. Thanks
Re: Dip stick tube hight 340 [Re: 340swing] #1158743
01/17/12 11:40 AM
01/17/12 11:40 AM
I'd trim the tube so with 4 qts in the sump on a level surface the stick shows exactly full but it'd probably be much easier the other way to remark the stick if your tube height isn't dead on
Re: Dip stick tube hight 340 [Re: RapidRobert] #1158744
01/18/12 01:26 PM
01/18/12 01:26 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Yeah, OEM "oil level indicators" were notoriously inaccurate back in the day. Level ground, 3 qts = "add" one more = "full". This is a smart idea on any muscle-era Mopar. I drill small holes, no ambiguity that way.
LA pans also really need a "picture frame" baffle at about the 3-qt. level.
Rick
Re: Dip stick tube hight 340 [Re: Rick_Ehrenberg] #1158745
01/18/12 02:23 PM
01/18/12 02:23 PM
Toronto, ON
ehbody Offline
ehbody  Offline
Toronto, ON
I recently did this following Rick's instructions.
Ended up cutting about an 1" off the dip stick tube to get correct reading for my 340.
Very happy now.
I used a mini tube cutter and had the alternator out already. Some tape to mark the location and measure twice cut once attitude. Plus something stuck in the tube to catch anything that might have fallen in.
Shawn 70 AAR
Re: Dip stick tube hight 340 [Re: ehbody] #1158746
01/18/12 03:03 PM
01/18/12 03:03 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Did cars with A/C use a longer tube to get up away from the belts more?
