Re: Dip stick tube hight 340
[Re: 340swing]
#1158743
01/17/12 11:40 AM
01/17/12 11:40 AM
RapidRobert
I'd trim the tube so with 4 qts in the sump on a level surface the stick shows exactly full but it'd probably be much easier the other way to remark the stick if your tube height isn't dead on
[Re: Rick_Ehrenberg]
#1158745
01/18/12 02:23 PM
01/18/12 02:23 PM
Posts: 288 Toronto, ON
ehbody
Toronto, ON
I recently did this following Rick's instructions. Ended up cutting about an 1" off the dip stick tube to get correct reading for my 340. Very happy now. I used a mini tube cutter and had the alternator out already. Some tape to mark the location and measure twice cut once attitude. Plus something stuck in the tube to catch anything that might have fallen in.
Shawn
70 AAR
