nitrous stick cars ? #1152117
01/07/12 11:16 AM
01/07/12 11:16 AM
ohio
Rich970 Offline OP
Rich970  Offline OP
ohio
I am curious about set ups whats being used for nitrous activation. timers, window switches, progresive ? thanks Rich
Re: nitrous stick cars ? [Re: Rich970] #1152118
01/07/12 11:19 AM
01/07/12 11:19 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
There was some discussion about this over on www.umtrnorth.com a while back.There was some great info exchanged there from real world racers.
Gus
64 Plymouth Savoy
Dana 60
Re: nitrous stick cars ? [Re: Rich970] #1152119
01/07/12 11:25 AM
01/07/12 11:25 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
With a stick car I would want a throttle switch with a window switch. Use a timer if you can't hook it off the line.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: nitrous stick cars ? [Re: fourgearsavoy] #1152120
01/07/12 01:23 PM
01/07/12 01:23 PM
ohio
Rich970 Offline OP
Rich970  Offline OP
ohio
thanks i will search there
Re: nitrous stick cars ? [Re: Rich970] #1152121
01/07/12 02:06 PM
01/07/12 02:06 PM
Camillus N.Y
rollerfork Offline
rollerfork  Offline
Camillus N.Y
I run a two stage plate. First stage comes on with a throttle switch with no timing out. Second stage is on the shifter handle and is hooked up to a digital 6 box that pulls the timing out. Kind of old school but it works great.
Re: nitrous stick cars ? [Re: rollerfork] #1152122
01/07/12 06:55 PM
01/07/12 06:55 PM
ohio
Rich970 Offline OP
Rich970  Offline OP
ohio
can i ask how you dont pull timing on the 1st stage ? you dont run it NA ? when do you hit the 2nd stage ? what trans ? thanks Rich
Re: nitrous stick cars ? [Re: Rich970] #1152123
01/07/12 08:49 PM
01/07/12 08:49 PM
Camillus N.Y
rollerfork Offline
rollerfork  Offline
Camillus N.Y
Motor has 34 degrees of timing on the first stage. First stage is 100 HP with good gas. I also run the motor at 34 NA with pump gas. Second stage is 125 HP and take 6 degrees out only if i run the second stage. I turn both on in first gear. first stage is on as soon as i take off and second one is on a little past the 60 foot timers. I run a Rankin trans that is similar to a G-Force. Hope this helps
Re: nitrous stick cars ? [Re: rollerfork] #1152124
01/07/12 09:11 PM
01/07/12 09:11 PM
ohio
Rich970 Offline OP
Rich970  Offline OP
ohio
it helps a lot thanks very much
Re: nitrous stick cars ? [Re: rollerfork] #1152125
01/07/12 09:13 PM
01/07/12 09:13 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
Cool car..... What's it run?? What clutch? What nitrous/fuel jets/fuel pressure??
If you can't handle the truth, you're living a lie.......
Re: nitrous stick cars ? [Re: rollerfork] #1152126
01/07/12 09:15 PM
01/07/12 09:15 PM
ohio
Rich970 Offline OP
Rich970  Offline OP
ohio
thats a very nice demon ! thanks again
Re: nitrous stick cars ? [Re: Rich970] #1152127
01/07/12 10:01 PM
01/07/12 10:01 PM
Camillus N.Y
rollerfork Offline
rollerfork  Offline
Camillus N.Y
No Problem. I run 2 regulators off a fuel log. One regulator for the motor is set at 7 pounds. Other Regulator runs both fuel solenoids and is set at 5 pounds. First stage is 57 square and 2 stage has a 64 square pill. I run a McLeod long style pressure plate with a Ram 6 puck disk. Best ET so far with both stages is 10.44 130.73 mph. Thats with a 2 1/2 inch exhaust with flowmasters. I know there is some more in it. Drove it to the track and drove it home.
Re: nitrous stick cars ? [Re: rollerfork] #1152128
01/07/12 10:13 PM
01/07/12 10:13 PM
Toronto
mshred Offline
mshred  Offline
Toronto
No Problem. I run 2 regulators off a fuel log. One regulator for the motor is set at 7 pounds. Other Regulator runs both fuel solenoids and is set at 5 pounds. First stage is 57 square and 2 stage has a 64 square pill. I run a McLeod long style pressure plate with a Ram 6 puck disk. Best ET so far with both stages is 10.44 130.73 mph. Thats with a 2 1/2 inch exhaust with flowmasters. I know there is some more in it. Drove it to the tack and drove it home.
non adjustable pressure plate? Those are some awesome times, and a great looking car too!
Re: nitrous stick cars ? [Re: mshred] #1152129
01/07/12 11:21 PM
01/07/12 11:21 PM
Camillus N.Y
rollerfork Offline
rollerfork  Offline
Camillus N.Y
mshred your car looks great to. Have a picture of it on my computer
Re: nitrous stick cars ? [Re: rollerfork] #1152130
01/08/12 06:56 AM
01/08/12 06:56 AM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
Cool.........What RPM are you launching at?
What's it run on nuts?
Re: nitrous stick cars ? [Re: Big Squeeze] #1152131
01/08/12 10:43 AM
01/08/12 10:43 AM
British Columbia
toddd Offline
toddd  Offline
British Columbia
Get a hold of Monte Smith.
Re: nitrous stick cars ? [Re: toddd] #1152132
01/08/12 02:48 PM
01/08/12 02:48 PM
Lehigh Acres, Florida
rickstershemi Offline
See a lot of guys running the "RICK'S SWITCH" looks like a straight forward approach to me that could be adapted for nitrous use
Rickster
Re: nitrous stick cars ? [Re: rickstershemi] #1152133
01/08/12 04:27 PM
01/08/12 04:27 PM
Camillus N.Y
rollerfork Offline
rollerfork  Offline
Camillus N.Y
I take off around 4500 RPM or so. On motor the car runs high 11's. The Ricks switch i have looked into and will probably go that route at some point thanks. Monte Smith is one off the best but i hate to ask for information when i dont run his product but thank you.
Re: nitrous stick cars ? [Re: rollerfork] #1152134
01/08/12 04:35 PM
01/08/12 04:35 PM
Toronto
mshred Offline
mshred  Offline
Toronto
thanks man!
Im trying to figure out how im going to wire up the nitrous on my 4 speed car. Do you leave off a two step? If so, how do you have the nitrous wired so that it only comes on after dumping the clutch?
Re: nitrous stick cars ? [Re: mshred] #1152135
01/08/12 05:08 PM
01/08/12 05:08 PM
Camillus N.Y
rollerfork Offline
rollerfork  Offline
Camillus N.Y
Hey, I do not use my 2-step as of yet. I just hold the pedal at 4500 and dump clutch and floor it and car takes off on a throttle switch (NOS) right out of the gate. There are many better ways to do it but it works for me. Then hope i dont miss a gear
