Re: nitrous stick cars ?
[Re: Rich970]
#1152118
01/07/12 11:19 AM
01/07/12 11:19 AM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
There was some discussion about this over on www.umtrnorth.com a while back.There was some great info exchanged there from real world racers. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Rich970]
#1152119
01/07/12 11:25 AM
01/07/12 11:25 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
With a stick car I would want a throttle switch with a window switch. Use a timer if you can't hook it off the line.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: Rich970]
#1152127
01/07/12 10:01 PM
01/07/12 10:01 PM
Posts: 84 Camillus N.Y
rollerfork
Camillus N.Y
No Problem. I run 2 regulators off a fuel log. One regulator for the motor is set at 7 pounds. Other Regulator runs both fuel solenoids and is set at 5 pounds. First stage is 57 square and 2 stage has a 64 square pill. I run a McLeod long style pressure plate with a Ram 6 puck disk. Best ET so far with both stages is 10.44 130.73 mph. Thats with a 2 1/2 inch exhaust with flowmasters. I know there is some more in it. Drove it to the track and drove it home.
[Re: rollerfork]
#1152128
01/07/12 10:13 PM
01/07/12 10:13 PM
Posts: 3,414 Toronto
mshred
Toronto
No Problem. I run 2 regulators off a fuel log. One regulator for the motor is set at 7 pounds. Other Regulator runs both fuel solenoids and is set at 5 pounds. First stage is 57 square and 2 stage has a 64 square pill. I run a McLeod long style pressure plate with a Ram 6 puck disk. Best ET so far with both stages is 10.44 130.73 mph. Thats with a 2 1/2 inch exhaust with flowmasters. I know there is some more in it. Drove it to the tack and drove it home.
non adjustable pressure plate? Those are some awesome times, and a great looking car too!
[Re: rollerfork]
#1152134
01/08/12 04:35 PM
01/08/12 04:35 PM
mshred
Toronto
mshred your car looks great to. Have a picture of it on my computer
thanks man!
Im trying to figure out how im going to wire up the nitrous on my 4 speed car. Do you leave off a two step? If so, how do you have the nitrous wired so that it only comes on after dumping the clutch?
