Newer Mini Starter in an Older Car #1145475
12/27/11 10:44 PM
12/27/11 10:44 PM
Out in Left Field, NY
bobs66440 Offline OP
I apologize if this has been posted a million times, but I couldn't find anything in the search.
I have been reading that the Autozone starter PN17181 designed for the newer Dodge truck will work on my 440. Is there any modification needed to make it work? Any additional info I need to know?
Thanks!
Re: Newer Mini Starter in an Older Car [Re: bobs66440] #1145476
12/27/11 10:54 PM
12/27/11 10:54 PM
Crofton, MD
bri440 Offline
bri440  Offline
Crofton, MD
I installed one on my 440. Had to remove a little casting slag from the block for clearance, but no modifications to the starter. Little bit of a challenge wrestling it in with headers, but it bolts right in.
Good Luck.
Re: Newer Mini Starter in an Older Car [Re: bri440] #1145477
12/27/11 10:57 PM
12/27/11 10:57 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
If you can stand the way they sound, get one for an early-mid 90s Dakota/Ram with a 318
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Newer Mini Starter in an Older Car [Re: 69L78Nova] #1145478
12/27/11 11:12 PM
12/27/11 11:12 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
I've used that exact one for years.
and some of the aftermarket ones have a "extension" bolted on the terminals. Remove that.
Re: Newer Mini Starter in an Older Car [Re: DANA60] #1145479
12/27/11 11:22 PM
12/27/11 11:22 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Re: Newer Mini Starter in an Older Car [Re: bobs66440] #1145480
12/27/11 11:32 PM
12/27/11 11:32 PM
Earth
tubedriver Offline
tubedriver  Offline
Earth
Just installed one on my 440.
Remove the terminal extension block, and grind on the starter case for block clearance, just a bit! I and others have put a split hose between the stud on the starter and the block since it comes VERY close to the block.
Make sure you hook up the wires before installing , you won't be able to once it is installed.
Re: Newer Mini Starter in an Older Car [Re: bobs66440] #1145481
12/27/11 11:32 PM
12/27/11 11:32 PM
Salvage is cheaper.
Mine is out of an '88 or so Pickup.
Re: Newer Mini Starter in an Older Car #1145482
12/28/11 11:04 AM
12/28/11 11:04 AM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
Mines been on my Dart for 10 years, got it off a 90 or so truck. $20 from the pull a part.
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: Newer Mini Starter in an Older Car [Re: bobs66440] #1145483
12/28/11 01:09 PM
12/28/11 01:09 PM
NY usa
540challenger Offline
NY usa
Yes they work well Like noted make sure that you don't need the small wire connentor of the car/truck. Not all aftermarket and factory starter have the removable terminal
Re: Newer Mini Starter in an Older Car #1145484
12/28/11 03:35 PM
12/28/11 03:35 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
Salvage is cheaper.
i used one from a smashed caravan for 25$ on my 500 strkr in a 62 dart and it works like new..
Re: Newer Mini Starter in an Older Car [Re: moparsquid] #1145485
12/28/11 04:21 PM
12/28/11 04:21 PM
BDW Online content
BDW  Online Content
Contact this guy directly, picked up mine for $55.
http://www.ebay.com/itm/MOPAR-MINI-START...=item27c1b51837
Re: Newer Mini Starter in an Older Car [Re: BDW] #1145486
12/28/11 07:00 PM
12/28/11 07:00 PM
Slantytown
DUFFMAN Offline
Ask And Ye Shall Receive
DUFFMAN  Offline
Slantytown
My Dad bought a starter for a 1998 Ram 318/360 and installed it in his 1974 Charger with a 360. I wasn't there, but he said the installation was easy. It sounds a little odd, but works great with with his headers.
No longer taking $h!t from anyone!
Re: Newer Mini Starter in an Older Car [Re: DUFFMAN] #1145487
12/28/11 07:18 PM
12/28/11 07:18 PM
If you have to take off the side terminals to make it fit, how is it wired?
Re: Newer Mini Starter in an Older Car [Re: bobs66440] #1145488
12/28/11 07:23 PM
12/28/11 07:23 PM
Kirkland, Washington
Pacnorthcuda Offline
Its sort of a terminal adapter--it mounts to existing terminals and basically just moves them. When you remove the adapter you expose terminals that you use.
Re: Newer Mini Starter in an Older Car [Re: bobs66440] #1145489
12/28/11 07:24 PM
12/28/11 07:24 PM
Two terminals are still there.
Think of the piece that you take off as an "extension".
Re: Newer Mini Starter in an Older Car #1145490
12/28/11 11:49 PM
12/28/11 11:49 PM
Ok. I get it. Good, thanks!
Re: Newer Mini Starter in an Older Car [Re: bobs66440] #1145491
12/29/11 12:01 AM
12/29/11 12:01 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Look at the tech archive link I posted above and you will see what you need to do. It has pictures with instructions.
Re: Newer Mini Starter in an Older Car [Re: stumpy] #1145492
12/29/11 12:05 AM
12/29/11 12:05 AM
I saw that, thanks. I just wasn't picturing it without the terminals, but now I see the other photo and I guess you end up with the two posts on the side.
Re: Newer Mini Starter in an Older Car [Re: bobs66440] #1145493
12/29/11 01:45 AM
12/29/11 01:45 AM
Central TX
roe Offline
roe  Offline
Central TX
Follow the tips that people have mentioned before. I had to grind on the nose cone of my starter for the clearance. I love it. Also, I got mine from autozone for like $100 or so, but it comes with a lifetime warranty. Anywhere in the country, if it gives out on me, I just go to the nearest autozone and swap it out for free. I like that piece of mind.
roe
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Newer Mini Starter in an Older Car [Re: roe] #1145494
12/29/11 05:28 PM
12/29/11 05:28 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
roe
I marched in to an Autozone and got one for a '92 Dakota 318. Took off the terminal extension and it bolted right up. Starts much faster.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
