Newer Mini Starter in an Older Car
#1145475
12/27/11 10:44 PM
12/27/11 10:44 PM
Posts: 1,880 Out in Left Field, NY
bobs66440
I apologize if this has been posted a million times, but I couldn't find anything in the search. I have been reading that the Autozone starter PN17181 designed for the newer Dodge truck will work on my 440. Is there any modification needed to make it work? Any additional info I need to know? Thanks!
Re: Newer Mini Starter in an Older Car
[Re: bri440]
#1145477
12/27/11 10:57 PM
12/27/11 10:57 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
If you can stand the way they sound, get one for an early-mid 90s Dakota/Ram with a 318
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
[Re: bobs66440]
#1145481
12/27/11 11:32 PM
12/27/11 11:32 PM
Salvage is cheaper.
Mine is out of an '88 or so Pickup.
#1145482
12/28/11 11:04 AM
12/28/11 11:04 AM
Posts: 10,968 Hampton, Ga.
70dart360
Green Meister
Green Meister
Hampton, Ga.
Mines been on my Dart for 10 years, got it off a 90 or so truck. $20 from the pull a part.
70 Dart Swinger
72 D-100 440 shortbed
76 Pinto, 68k 21mpg!
#1145484
12/28/11 03:35 PM
12/28/11 03:35 PM
Posts: 1,107 Spring Valley ,Ca.
moparsquid
Spring Valley ,Ca.
Salvage is cheaper.
i used one from a smashed caravan for 25$ on my 500 strkr in a 62 dart and it works like new..
[Re: BDW]
#1145486
12/28/11 07:00 PM
12/28/11 07:00 PM
Posts: 11,269 Slantytown
DUFFMAN
Ask And Ye Shall Receive
Slantytown
My Dad bought a starter for a 1998 Ram 318/360 and installed it in his 1974 Charger with a 360. I wasn't there, but he said the installation was easy. It sounds a little odd, but works great with with his headers.
No longer taking $h!t from anyone!
[Re: bobs66440]
#1145488
12/28/11 07:23 PM
12/28/11 07:23 PM
Posts: 21,831 Kirkland, Washington
Pacnorthcuda
If you have to take off the side terminals to make it fit, how is it wired?
Its sort of a terminal adapter--it mounts to existing terminals and basically just moves them. When you remove the adapter you expose terminals that you use.
[Re: bobs66440]
#1145489
12/28/11 07:24 PM
12/28/11 07:24 PM
Two terminals are still there.
Think of the piece that you take off as an "extension".
[Re: bobs66440]
#1145493
12/29/11 01:45 AM
12/29/11 01:45 AM
Posts: 3,344 Central TX
roe
Central TX
Follow the tips that people have mentioned before. I had to grind on the nose cone of my starter for the clearance. I love it. Also, I got mine from autozone for like $100 or so, but it comes with a lifetime warranty. Anywhere in the country, if it gives out on me, I just go to the nearest autozone and swap it out for free. I like that piece of mind.
roe
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
[Re: roe]
#1145494
12/29/11 05:28 PM
12/29/11 05:28 PM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
roe
I marched in to an Autozone and got one for a '92 Dakota 318. Took off the terminal extension and it bolted right up. Starts much faster.
