who has pushed the rear back on a dart for tire room #1144471
12/26/11 05:49 PM
12/26/11 05:49 PM
mo
ALKYW5DART Offline OP
mo
i need to push my rearend back on my 71 dart for tire clearence, who has done this and does it affect traction or should i cut the rear quarter in front of tire and keep rearend in stock location thanks guys
Re: who has pushed the rear back on a dart for tire room [Re: ALKYW5DART] #1144472
12/26/11 06:00 PM
12/26/11 06:00 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I moved my rear end back on my b body with no issues. Just like 3/4" or so. gets the tire in the center of the wheel well.
67' charger 499 RB 10.57 at 127
Re: who has pushed the rear back on a dart for tire room [Re: ALKYW5DART] #1144473
12/26/11 06:08 PM
12/26/11 06:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
How much do you need to move it
Re: who has pushed the rear back on a dart for tire room [Re: MR_P_BODY] #1144474
12/26/11 06:15 PM
12/26/11 06:15 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
I moved the rear back in my Valiant 1" when we did the spring relocation. Not a big deal, but you may need to lengthen the driveshaft.
Re: who has pushed the rear back on a dart for tire room [Re: ALKYW5DART] #1144475
12/26/11 06:16 PM
12/26/11 06:16 PM
Don't extend the wheel base backwards It is not hard to do a nice job on the front edge of the wheelwells on those year(1967to1973) Darts, I have done it with a If anything move it forward some when your doing the wheelwells
Re: who has pushed the rear back on a dart for tire room [Re: Cab_Burge] #1144476
12/26/11 06:17 PM
12/26/11 06:17 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Mine is moved back 1"
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: who has pushed the rear back on a dart for tire room [Re: bigtimeauto] #1144477
12/26/11 06:19 PM
12/26/11 06:19 PM
Guitar Jones Offline
I moved mine 2.5" forward when we built my car. Moved the front forward .75".
Re: who has pushed the rear back on a dart for tire room [Re: Guitar Jones] #1144478
12/26/11 06:30 PM
12/26/11 06:30 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I beat the front lips in some is all I did on my 71 and the lips are rolled! the easiest way is prolly the offset block! some weld the holes shut on the perches and re drill there... I run a 315 radial though.
http://www.airbagit.com/product-p/blo-0-gm6072.htm
Mopar Performance
Re: who has pushed the rear back on a dart for tire room [Re: moparniac] #1144479
12/26/11 07:09 PM
12/26/11 07:09 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
cut n fold
Re: who has pushed the rear back on a dart for tire room [Re: rebel] #1144480
12/26/11 07:34 PM
12/26/11 07:34 PM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
Mine are moved back 1" 29 X 10 slicks
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: who has pushed the rear back on a dart for tire room [Re: DragDart360] #1144481
12/26/11 08:15 PM
12/26/11 08:15 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Stock spring hangers?
Cut some plate thickness that you need to move it that looks like an E and slide it between front hanger and frame. You can also get thinner plate and stack them.
I made some offset hangers and installed bolts long enough to move the rear 1" + back using the above method.
Re: who has pushed the rear back on a dart for tire room [Re: RobX4406] #1144482
12/26/11 08:19 PM
12/26/11 08:19 PM
Can , Nova Scotia , Cape Breto...
caper Offline
caper  Offline
I moved my rear back 1 1/2 in.
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
Re: who has pushed the rear back on a dart for tire room [Re: MR_P_BODY] #1144483
12/26/11 09:09 PM
12/26/11 09:09 PM
mo
mo
about 3/4 of an inch
Re: who has pushed the rear back on a dart for tire room [Re: ALKYW5DART] #1144484
12/26/11 09:19 PM
12/26/11 09:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You can put 3/4" plates in front of your front hangers
and then (if you want) put a set of sliders on the
rear to eliminate the shackles... it wont hurt your
weight distribution bad enough to hurt in traction
Re: who has pushed the rear back on a dart for tire room [Re: ALKYW5DART] #1144485
12/26/11 09:26 PM
12/26/11 09:26 PM
Super Scamp Offline
Super Scamp  Offline
Mine is moved 3/4" My setup BB Dana 4-link Alum.3.5 shaft 55 1/2 long with Glide. Also when building the back half I used 33 x 16.5 x 15 to do the setup in. Just incase I need to run a BIG Tire setup with 604" motor.
Just One Man's Opinion Mopar Mafia Racing
Re: who has pushed the rear back on a dart for tire room [Re: ALKYW5DART] #1144486
12/26/11 09:31 PM
12/26/11 09:31 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
back? I have a buddy that ran a 67 Valiant for years. he moved the rear forward 2 or 3"..of course it was tubbed. I had a 68 Dart I trimmed the front of each wheel opening o I could get the slicks on and off easier.
Coming soon!!!!
Re: who has pushed the rear back on a dart for tire room [Re: Mr.Yuck] #1144487
12/26/11 10:36 PM
12/26/11 10:36 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Yes 'back', if you look at Dragdart360's photo you can see how nice it looks moved back because it also fills the rear opening of the quarter panel some. Moving forward 2 or 3 inches would look goofy unless it was a 35" tall tire.
Re: who has pushed the rear back on a dart for tire room [Re: ProSport] #1144488
12/26/11 10:44 PM
12/26/11 10:44 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
It was a big tire car...9.50's It was done more for weight distro and traction not for looks. I think the engine was moved back as well.
Re: who has pushed the rear back on a dart for tire room [Re: ProSport] #1144489
12/26/11 10:49 PM
12/26/11 10:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you wanted to move it forward the only real way
is to cut the quarter and slide the front forward...
moving it forward does help in the weight bias and
transfer
Re: who has pushed the rear back on a dart for tire room [Re: bigtimeauto] #1144490
12/26/11 11:32 PM
12/26/11 11:32 PM
mo
mo
what size tire are you running and any better pics of side view thanks
