Re: who has pushed the rear back on a dart for tire room
[Re: ALKYW5DART]
#1144472
12/26/11 06:00 PM
12/26/11 06:00 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I moved my rear end back on my b body with no issues. Just like 3/4" or so. gets the tire in the center of the wheel well.
67' charger 499 RB
10.57 at 127
[Re: ALKYW5DART]
#1144473
12/26/11 06:08 PM
12/26/11 06:08 PM
Posts: 52,972 Romeo MI
MR_P_BODY
i need to push my rearend back on my 71 dart for tire clearence, who has done this and does it affect traction or should i cut the rear quarter in front of tire and keep rearend in stock location thanks guys
How much do you need to move it ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1144474
12/26/11 06:15 PM
12/26/11 06:15 PM
Posts: 20,212 Park Forest, IL
slantzilla
Park Forest, IL
I moved the rear back in my Valiant 1" when we did the spring relocation. Not a big deal, but you may need to lengthen the driveshaft.
[Re: bigtimeauto]
#1144477
12/26/11 06:19 PM
12/26/11 06:19 PM
Posts: 20,671 in a cattle trailer down by th...
Guitar Jones
I moved mine 2.5" forward when we built my car. Moved the front forward .75".
[Re: Guitar Jones]
#1144478
12/26/11 06:30 PM
12/26/11 06:30 PM
Posts: 6,295 U.S.
moparniac
U.S.
I beat the front lips in some is all I did on my 71 and the lips are rolled! the easiest way is prolly the offset block! some weld the holes shut on the perches and re drill there... I run a 315 radial though. http://www.airbagit.com/product-p/blo-0-gm6072.htm
Mopar Performance
[Re: moparniac]
#1144479
12/26/11 07:09 PM
12/26/11 07:09 PM
Posts: 4,647 aotearoa
rebel
aotearoa
[Re: MR_P_BODY]
#1144483
12/26/11 09:09 PM
12/26/11 09:09 PM
Posts: 215 mo
ALKYW5DART
mo
about 3/4 of an inch
[Re: ALKYW5DART]
#1144484
12/26/11 09:19 PM
12/26/11 09:19 PM
MR_P_BODY
You can put 3/4" plates in front of your front hangers and then (if you want) put a set of sliders on the rear to eliminate the shackles... it wont hurt your weight distribution bad enough to hurt in traction ![](/ubbthreads/images/graemlins/wave.gif)
[Re: ProSport]
#1144488
12/26/11 10:44 PM
12/26/11 10:44 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
back? I have a buddy that ran a 67 Valiant for years. he moved the rear forward 2 or 3"..of course it was tubbed. I had a 68 Dart I trimmed the front of each wheel opening o I could get the slicks on and off easier.
Yes 'back', if you look at Dragdart360's photo you can see how nice it looks moved back because it also fills the rear opening of the quarter panel some. Moving forward 2 or 3 inches would look goofy unless it was a 35" tall tire.
It was a big tire car...9.50's It was done more for weight distro and traction not for looks. I think the engine was moved back as well.
[Re: ProSport]
#1144489
12/26/11 10:49 PM
12/26/11 10:49 PM
MR_P_BODY
If you wanted to move it forward the only real way is to cut the quarter and slide the front forward... moving it forward does help in the weight bias and transfer ![](/ubbthreads/images/graemlins/wave.gif)
[Re: bigtimeauto]
#1144490
12/26/11 11:32 PM
12/26/11 11:32 PM
Posts: 215 mo
ALKYW5DART
mo
Mine is moved back 1"
what size tire are you running and any better pics of side view thanks
