primer color #1144108
12/25/11 10:28 PM
12/25/11 10:28 PM
ontario, canada
plumcrazy704406 Offline OP
ontario, canada
what color should the primer be on a 68' barracuda
thx moparts
This thought may not be politically correct, but is an opinion offered. It may be correct? or it may be wrong? It is not designed to appease those needing shelter from the real world.
Re: primer color [Re: plumcrazy704406] #1144109
12/25/11 11:41 PM
12/25/11 11:41 PM
Iowa
Hey19 Offline
Hey19  Offline
Iowa
My 69 barracuda had regular medium gray color primer under the sunfire yellow.
Re: primer color [Re: plumcrazy704406] #1144110
12/26/11 01:11 AM
12/26/11 01:11 AM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
thx moparts
Are you specifically talking about underside primer?
I have pictures of virgin under side primer that has been protected by factory undercoating forever.
Re: primer color [Re: Hey19] #1144111
12/26/11 01:38 AM
12/26/11 01:38 AM
Tri-Cities, Washington
V
VITC_GTX Offline
VITC_GTX  Offline
V
Funny, my '69 barracuda has a redish brown primer under the original sunfire yellow paint. Different assembly plant, different batch of cars, primer or...
Re: primer color [Re: VITC_GTX] #1144112
12/26/11 02:39 AM
12/26/11 02:39 AM
So Cal
So Cal
Where all 67-69 Barracudas built at the same plant?
Where specifically on the car did you see the redish brown primer.
The picture below is the inside wheel tub on my 68 Dart conv. built at Hamtramak.
MOPARMIKE69, notes similar findings under his 69.5. See his picture and more discussion on this here: https://board.moparts.org/ubbthreads/show...rue#Post6838352
I've seen redish brown primer bleed through the top of worn original paint.
Re: primer color [Re: autoxcuda] #1144113
12/26/11 02:50 AM
12/26/11 02:50 AM
So Cal
So Cal
Some pictures of the undercarriage of my 68 Barracuda California car with undercoating that trans fluid and pressure washer have broken off.
***My bar is RR1 Maroon, Dark Red. So this is not primer just exterior Maroon overspray.
Re: primer color [Re: autoxcuda] #1144114
12/26/11 03:20 AM
12/26/11 03:20 AM
V
VITC_GTX Offline
VITC_GTX  Offline
V
I was wrong. I just went out to the shop and looked at the car. I block sanded my orignal paint in prep for a scuff and shoot paint job. What I see is a thin layer of grey under the yellow with the red-ish brown under the grey. The grey is so thin on my car that it goes from yellow to red in about 2 strokes of the sanding block. It's this way over the entire car.
Re: primer color [Re: VITC_GTX] #1144115
12/26/11 11:00 AM
12/26/11 11:00 AM
ontario, canada
ontario, canada
pic attached
Re: primer color [Re: plumcrazy704406] #1144116
12/26/11 02:00 PM
12/26/11 02:00 PM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
FYI for anyone interested.
SPI has a new Red Oxide epoxy primer out. It can be mixed with their white or black epoxy if necessary to match OEM colors.
And no, I don't work for them just passing on information to anyone interested.
Re: primer color [Re: plumcrazy704406] #1144117
12/26/11 07:54 PM
12/26/11 07:54 PM
So Cal
So Cal
pic attached
What part of the car is that picture taken at?
