primer color
#1144108
12/25/11 10:28 PM
12/25/11 10:28 PM
Posts: 273 ontario, canada
plumcrazy704406
ontario, canada
what color should the primer be on a 68' barracuda thx moparts
This thought may not be politically correct, but is an opinion offered. It may be correct? or it may be wrong? It is not designed to appease those needing shelter from the real world.
Re: primer color
[Re: plumcrazy704406]
#1144110
12/26/11 01:11 AM
12/26/11 01:11 AM
Posts: 27,468 So Cal
autoxcuda
So Cal
Are you specifically talking about underside primer?
I have pictures of virgin under side primer that has been protected by factory undercoating forever.
Re: primer color
[Re: Hey19]
#1144111
12/26/11 01:38 AM
12/26/11 01:38 AM
Posts: 4,929 Tri-Cities, Washington
VITC_GTX
My 69 barracuda had regular medium gray color primer under the sunfire yellow.
Funny, my '69 barracuda has a redish brown primer under the original sunfire yellow paint. Different assembly plant, different batch of cars, primer or...
Re: primer color
[Re: autoxcuda]
#1144114
12/26/11 03:20 AM
12/26/11 03:20 AM
VITC_GTX
Where all 67-69 Barracudas built at the same plant?
Where specifically on the car did you see the redish brown primer.
The picture below is the inside wheel tub on my 68 Dart conv. built at Hamtramak.
MOPARMIKE69, notes similar findings under his 69.5. See his picture and more discussion on this here: https://board.moparts.org/ubbthreads/show...rue#Post6838352
I've seen redish brown primer bleed through the top of worn original paint.
I was wrong. I just went out to the shop and looked at the car. I block sanded my orignal paint in prep for a scuff and shoot paint job. What I see is a thin layer of grey under the yellow with the red-ish brown under the grey. The grey is so thin on my car that it goes from yellow to red in about 2 strokes of the sanding block. It's this way over the entire car.
Re: primer color
[Re: VITC_GTX]
#1144115
12/26/11 11:00 AM
12/26/11 11:00 AM
plumcrazy704406
ontario, canada
pic attached
Re: primer color
#1144117
12/26/11 07:54 PM
12/26/11 07:54 PM
autoxcuda
So Cal
pic attached
What part of the car is that picture taken at?
