My 69 barracuda had regular medium gray color primer under the sunfire yellow.
Funny, my '69 barracuda has a redish brown primer under the original sunfire yellow paint. Different assembly plant, different batch of cars, primer or...
Where all 67-69 Barracudas built at the same plant?
Where specifically on the car did you see the redish brown primer.
The picture below is the inside wheel tub on my 68 Dart conv. built at Hamtramak.
MOPARMIKE69, notes similar findings under his 69.5. See his picture and more discussion on this here: https://board.moparts.org/ubbthreads/show...rue#Post6838352
I've seen redish brown primer bleed through the top of worn original paint.
I was wrong. I just went out to the shop and looked at the car. I block sanded my orignal paint in prep for a scuff and shoot paint job. What I see is a thin layer of grey under the yellow with the red-ish brown under the grey. The grey is so thin on my car that it goes from yellow to red in about 2 strokes of the sanding block. It's this way over the entire car.
