Balancing issue M/T sportsman SR fronts #1142582
12/23/11 05:18 PM
12/23/11 05:18 PM
Missouri
galen Offline OP
galen  Offline OP
Missouri
One tire took 1/2 oz total to balance. The other tire takes 3.5 oz in one area. Pulled tire off and checked the wheel balance and it is perfect. Checked this on 2 spin machines and even stuck it on my old bubble balancer. Tire runout is fine. Has a high speed shake like an out of balance tire. It spins up 0 with 3.5 oz of weight on it but its a big hunk of lead in one spot. No warranty because they have a couple years on them building the car. Should I make a tire swing out of it?
Re: Balancing issue M/T sportsman SR fronts [Re: galen] #1142583
12/23/11 08:14 PM
12/23/11 08:14 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
try breaking it down and rotate the tire into a different position
I am truckless..
Re: Balancing issue M/T sportsman SR fronts [Re: 340SHORTY] #1142584
12/23/11 09:59 PM
12/23/11 09:59 PM
Missouri
galen Offline OP
galen  Offline OP
Missouri
tried 1/2 a turn on the rim no change.
Re: Balancing issue M/T sportsman SR fronts [Re: galen] #1142585
12/23/11 10:08 PM
12/23/11 10:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats alot of weight for a (so called small) front
runner..... time for a new one.... JMO
Re: Balancing issue M/T sportsman SR fronts [Re: MR_P_BODY] #1142586
12/24/11 05:16 AM
12/24/11 05:16 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I am truckless..
Re: Balancing issue M/T sportsman SR fronts [Re: galen] #1142587
12/24/11 11:19 AM
12/24/11 11:19 AM
ill
dennismopar73 Offline
ill
change it to the other rim , rotate if needed!
also , be carefull that the center is not 'running lose '
Re: Balancing issue M/T sportsman SR fronts [Re: dennismopar73] #1142588
12/24/11 12:19 PM
12/24/11 12:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
He said they spun up just the wheel alone and it
was fine so its in the tire... he also rotated it
a 1/2 turn on the wheel(which wouldnt have made a
difference since the wheel was true)
Re: Balancing issue M/T sportsman SR fronts [Re: MR_P_BODY] #1142589
12/24/11 12:51 PM
12/24/11 12:51 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Flip the tire over.Had some at work that took lots of weight.Sometimes flipping them over will work.Same with rotating them Ive had to rotate some 3 or 4 times.Sometime you just get a tire that takes weight.Rocky
Chrysler Firepower
Re: Balancing issue M/T sportsman SR fronts [Re: therocks] #1142590
12/25/11 11:48 PM
12/25/11 11:48 PM
Iowa
Hey19 Offline
Hey19  Offline
Iowa
I think it is MT for some reason. I just bought 4 of their tires for my street rod and they took a ton of weight on new rims.
Re: Balancing issue M/T sportsman SR fronts [Re: Hey19] #1142591
12/26/11 12:46 AM
12/26/11 12:46 AM
Missouri
galen Offline OP
galen  Offline OP
Missouri
I went ahead and ordered another tire. 3.5 oz on such a small tire on a 3.5 rim was a big chunk of lead.
Re: Balancing issue M/T sportsman SR fronts [Re: galen] #1142592
12/26/11 04:30 PM
12/26/11 04:30 PM
Any chance of getting it balanced on the car? Probally to late now, sorry.
