Re: Balancing issue M/T sportsman SR fronts
[Re: galen]
#1142583
12/23/11 08:14 PM
12/23/11 08:14 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
try breaking it down and rotate the tire into a different position
I am truckless..
[Re: galen]
#1142585
12/23/11 10:08 PM
12/23/11 10:08 PM
Posts: 52,972 Romeo MI
MR_P_BODY
tried 1/2 a turn on the rim no change.
Thats alot of weight for a (so called small) front runner..... time for a new one.... JMO
[Re: galen]
#1142587
12/24/11 11:19 AM
12/24/11 11:19 AM
Posts: 2,177 ill
dennismopar73
ill
change it to the other rim , rotate if needed! also , be carefull that the center is not 'running lose '
[Re: dennismopar73]
#1142588
12/24/11 12:19 PM
12/24/11 12:19 PM
MR_P_BODY
He said they spun up just the wheel alone and it was fine so its in the tire... he also rotated it a 1/2 turn on the wheel(which wouldnt have made a difference since the wheel was true)
[Re: MR_P_BODY]
#1142589
12/24/11 12:51 PM
12/24/11 12:51 PM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
Flip the tire over.Had some at work that took lots of weight.Sometimes flipping them over will work.Same with rotating them Ive had to rotate some 3 or 4 times.Sometime you just get a tire that takes weight.Rocky
Chrysler Firepower
[Re: galen]
#1142592
12/26/11 04:30 PM
12/26/11 04:30 PM
Posts: 43,284 Bend,OR USA
Cab_Burge
Any chance of getting it balanced on the car? Probally to late now, sorry.
