Average SB deck height and block decking questions #1142564
12/23/11 04:22 PM
12/23/11 04:22 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Have a few questions about
So I have my block at the machine shop and before deciding what pistons I am going with I had the machine shop measure the 4 corners of the block. Shortest side is 9.590". How common is it for the blocks to be off this much? Machine shop told me it is nothing to worry about but just wanted to check.
Also the machine shop told me expect the overall deck height of the entire block to be about .005" shorter than the 9.590" height of the current shortest corner after squaring up the block. Does this sound about right? Is that much material usually removed in squaring up a block's deck surfaces?
I have never dealt with getting a block machined before, so this is all new to me. Just for some background the combo is a 360 3.58" stroke, 6.123" rod, and SRP piston 142069 that will get me 9.583" overall deck height. I want to zero deck it, so if the block would be machined to about 9.585", they would have to take off another .002" to get me at zero deck. Does this sound like a lot of material to be removing?
I know it may seem I am overthinking things, and I do trust the machine shop, but this is just something I have never done before and getting to hear other's experiences always help although I do realize there is more than one way of doing things
Re: Average SB deck height and block decking questions [Re: mshred] #1142565
12/23/11 04:51 PM
12/23/11 04:51 PM
The Great White North
RAMM Offline
RAMM  Offline
How much do you think .005" really is? That is less than normal deck milling IMO. I have decked blocks .040" with no issues. Sounds like the shop is doing a good job. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Average SB deck height and block decking questions [Re: RAMM] #1142566
12/23/11 05:01 PM
12/23/11 05:01 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
I know it's not a lot, I just wasn't sure what the norm was for taking material off these blocks...call me stupid, naive, extra cautious etc. but I just felt more comfortable to ask than ponder in my head.
That said, the shop is very reputable and they do some mopar stuff, but I figured I would ask the mopar crowd. Good to know that taking off about .017" isn't much then compared to what others have done
Re: Average SB deck height and block decking questions [Re: mshred] #1142567
12/23/11 05:11 PM
12/23/11 05:11 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Its nothing to even remotely think about. Its normal and the shop will know what to do. .008 is a " normal" clean up, and even .020 is nothing anymore to make pistons zero deck.
RIP Monte Smith
Re: Average SB deck height and block decking questions [Re: CompWedgeEngines] #1142568
12/23/11 07:04 PM
12/23/11 07:04 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
My block was cut .080 about 20 years ago. Absolutely no problems, but its a PITA when you need new pistons. Customs aren't cheap.
Yeah, it's got a smallblock.
Re: Average SB deck height and block decking questions [Re: 340B5] #1142569
12/23/11 08:55 PM
12/23/11 08:55 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
I have seem some blocks that varied by as much as 0.015" from front to back, I wouldn't lose sleep over it!
Alan Jones
Re: Average SB deck height and block decking questions [Re: LA360] #1142570
12/23/11 09:10 PM
12/23/11 09:10 PM
organ
maximum entropy Offline
organ
i did a bb mopar a while back that not only had .010 slope (not unusual at all), but one end of one bank was OVER 10.725! heh. taking .020 or .025 off is totally normal to get zero deck. it all depends on your parts (and head gaskets).
Re: Average SB deck height and block decking questions [Re: mshred] #1142571
12/23/11 10:29 PM
12/23/11 10:29 PM
Alberta Canada
StrokerAspen Offline
Alberta Canada
Hey Matt, it sounds like your on the right track.My 340 was .055" off the deck, and .055" off the heads. We used a mopar replacement 340 forged piston back then, and the CD was not given, so things had to be cut to get things right.
I had to cut . 040" off my R3. It came as a 9.600" and I had planned for a 9.560" deck, since that was what my first R3 block came as.
-Kenny
Re: Average SB deck height and block decking questions [Re: StrokerAspen] #1142572
12/23/11 10:36 PM
12/23/11 10:36 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
my x-block was 9.350
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Average SB deck height and block decking questions [Re: dusturbd340W5] #1142573
12/23/11 10:56 PM
12/23/11 10:56 PM
Alberta Canada
Alberta Canada
Holy Smokes! Before you did any cutting??
Re: Average SB deck height and block decking questions [Re: StrokerAspen] #1142574
12/23/11 10:58 PM
12/23/11 10:58 PM
Kissimmee Fl.
Kissimmee Fl.
no that was finished product it was 9.358/9.360 when I got it and we squared it to 9.350
Re: Average SB deck height and block decking questions [Re: dusturbd340W5] #1142575
12/23/11 11:09 PM
12/23/11 11:09 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
9.350 sounds way off, as delivered they are just a hair under an oem block deck height.
Keep in mind just like many blocks produced there are some ducks that wont swim, ON the NOS X blocks I have if they dont have the org paperwork and its a shelf block, I pay them to have it sonic checked as well as a couple other things before buying them.
Some are sorta like the w5 heads, hit and miss.
This last one I took in I thought would have a high deck due the depth the head studs started but it was dead on and only .005 off end to end and was corrected.
Re: Average SB deck height and block decking questions [Re: mshred] #1142576
12/23/11 11:57 PM
12/23/11 11:57 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
Standard LA small block deck height is 9.56 so even your shortest side is 0.030 too high. At 9.56 the piston/rod combo you wish to use would have a positive deck height, ie. the piston would stick up out of the block assuming that the 9.583 # is correct for zero deck. In the FWIW dept. I personally don't care to go for absolute zero deck.I prefer to have the piston .005 in the hole. My reasoning goes like this: with a standard .039 thick gasket you will still have excellent quench and the compression loss is minimal. You will also have something to work with in case you have a head gasket failure that results in etching of the block surface. With a true zero deck any deck damage that may occur will not only require a clean up cut to the decks but you may well have to mill every piston top as well in order to maintain sufficient piston to head clearance.
Re: Average SB deck height and block decking questions [Re: quick77rt ] #1142577
12/24/11 12:32 AM
12/24/11 12:32 AM
Kissimmee Fl.
Kissimmee Fl.
I got the block used from Kent Ritter it was a round d round motor to begin with and he said it was not uncommon for them to cut them that much.
Re: Average SB deck height and block decking questions [Re: 5spdcuda] #1142578
12/24/11 12:39 AM
12/24/11 12:39 AM
Kissimmee Fl.
Kissimmee Fl.
I have seen a number of blocks come in right at 9.600
Re: Average SB deck height and block decking questions [Re: 5spdcuda] #1142579
12/24/11 01:13 PM
12/24/11 01:13 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
well even if my block is higher than standard specs the piston/rod combo I chose is still shorter than what it currently is. I was actually thinking of getting the block milled to 9.585" and the deck height of the rotating assembly at 9.853" still so that I drop the compression ever so slightly and don't run any risk of detonation on the 94 octane pump gas here. Using a .039" gasket with good quench I have seen people say that 10.5:1 is acceptable with premium pump gas, but with how much im going to street drive I don't want to chance having to mix fuel.
thanks for this info btw!
Re: Average SB deck height and block decking questions [Re: mshred] #1142580
12/24/11 01:15 PM
12/24/11 01:15 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
to everyone else, thank you for the replies, definitely makes me feel more comfortable
Like I said, this is a first for me, and even though I know we are only talking about thousandths worth of material here, I just don't want to screw anything up on my end in choosing this combo since I can hardly afford to do it once, let alone twice lol
thanks
Re: Average SB deck height and block decking questions [Re: dusturbd340W5] #1142581
12/24/11 04:36 PM
12/24/11 04:36 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
Thanks for the correction, I am getting old and forgetful. 9.60 is the correct # for standard LA deck height.
