Re: Average SB deck height and block decking questions
[Re: mshred]
#1142565
12/23/11 04:51 PM
12/23/11 04:51 PM
Posts: 1,051 The Great White North
RAMM
How much do you think .005" really is? That is less than normal deck milling IMO. I have decked blocks .040" with no issues. Sounds like the shop is doing a good job. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: RAMM]
#1142566
12/23/11 05:01 PM
12/23/11 05:01 PM
Posts: 3,420 Toronto
mshred
Toronto
I know it's not a lot, I just wasn't sure what the norm was for taking material off these blocks...call me stupid, naive, extra cautious etc. but I just felt more comfortable to ask than ponder in my head.
That said, the shop is very reputable and they do some mopar stuff, but I figured I would ask the mopar crowd. Good to know that taking off about .017" isn't much then compared to what others have done
[Re: mshred]
#1142567
12/23/11 05:11 PM
12/23/11 05:11 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Its nothing to even remotely think about. Its normal and the shop will know what to do. .008 is a " normal" clean up, and even .020 is nothing anymore to make pistons zero deck.
RIP Monte Smith
[Re: CompWedgeEngines]
#1142568
12/23/11 07:04 PM
12/23/11 07:04 PM
Posts: 1,532 off the grid
340B5
off the grid
My block was cut .080 about 20 years ago. Absolutely no problems, but its a PITA when you need new pistons. Customs aren't cheap.
Yeah, it's got a smallblock.
[Re: 340B5]
#1142569
12/23/11 08:55 PM
12/23/11 08:55 PM
Posts: 6,146 Melbourne , Australia
LA360
I have seem some blocks that varied by as much as 0.015" from front to back, I wouldn't lose sleep over it!
Alan Jones
[Re: LA360]
#1142570
12/23/11 09:10 PM
12/23/11 09:10 PM
Posts: 5,080 organ
maximum entropy
organ
i did a bb mopar a while back that not only had .010 slope (not unusual at all), but one end of one bank was OVER 10.725! heh. taking .020 or .025 off is totally normal to get zero deck. it all depends on your parts (and head gaskets).
[Re: dusturbd340W5]
#1142575
12/23/11 11:09 PM
12/23/11 11:09 PM
quick77rt
Parts Problem
Parts Problem
9.350 sounds way off, as delivered they are just a hair under an oem block deck height. Keep in mind just like many blocks produced there are some ducks that wont swim, ON the NOS X blocks I have if they dont have the org paperwork and its a shelf block, I pay them to have it sonic checked as well as a couple other things before buying them. Some are sorta like the w5 heads, hit and miss. This last one I took in I thought would have a high deck due the depth the head studs started but it was dead on and only .005 off end to end and was corrected. Quote:
my x-block was 9.350
Holy Smokes! Before you did any cutting??
no that was finished product it was 9.358/9.360 when I got it and we squared it to 9.350
[Re: 5spdcuda]
#1142579
12/24/11 01:13 PM
12/24/11 01:13 PM
mshred
Toronto
Standard LA small block deck height is 9.56 so even your shortest side is 0.030 too high. At 9.56 the piston/rod combo you wish to use would have a positive deck height, ie. the piston would stick up out of the block assuming that the 9.583 # is correct for zero deck. In the FWIW dept. I personally don't care to go for absolute zero deck.I prefer to have the piston .005 in the hole. My reasoning goes like this: with a standard .039 thick gasket you will still have excellent quench and the compression loss is minimal. You will also have something to work with in case you have a head gasket failure that results in etching of the block surface. With a true zero deck any deck damage that may occur will not only require a clean up cut to the decks but you may well have to mill every piston top as well in order to maintain sufficient piston to head clearance.
well even if my block is higher than standard specs the piston/rod combo I chose is still shorter than what it currently is. I was actually thinking of getting the block milled to 9.585" and the deck height of the rotating assembly at 9.853" still so that I drop the compression ever so slightly and don't run any risk of detonation on the 94 octane pump gas here. Using a .039" gasket with good quench I have seen people say that 10.5:1 is acceptable with premium pump gas, but with how much im going to street drive I don't want to chance having to mix fuel.
thanks for this info btw!
