Re: Bad rollover after run , driver loses his life
[Re: bigdad]
#1139116
12/19/11 09:07 AM
12/19/11 09:07 AM
Challenger 1
Cincinnati, Ohio
So sorry to hear this. IMO it is so stupid to put a car in nutreul when going through the lights. Accidents like this is why. I doin't care what kind of lock out your shifter has, it's bad and dangerous idea. Pushing in the clutch is a different deal all together.
BTW it was one of the things Frank Haley taught us not to do when I went to his drag racing school.
Someone said it helps keep the the car from overheating?? BS
[Re: bigdad]
#1139117
12/19/11 10:20 AM
12/19/11 10:20 AM
Posts: 5,894 Florida
Locomotion
Sad story of an unfortunate case of driver error. A reminder for the rest of us to be extra cautious.
I can't quite put my finger on it, but one line by the author really irritates. It just doesn't seem appropriate or necessary: "He purchased the $7,000 death car in June."
A sorry effort at sensationalism, perhaps?
[Re: Locomotion]
#1139118
12/19/11 11:00 AM
12/19/11 11:00 AM
Posts: 5,160 Texas
dannysbee
Texas
I agree very inappropriate. Looks like it was a 64 Hemi car. I believe those had aluminum doors. You have to wonder if the door would have been steel would the result been the same. I six point roll bar and 5 point harness would have saved his life. Very sad.
Getting old just means you were smarter than some and luckier than others.
[Re: Locomotion]
#1139120
12/19/11 12:50 PM
12/19/11 12:50 PM
Posts: 34,880 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I noticed that too, I suppose in that time drag racing was still frowned upon ..
[Re: Sixpak]
#1139122
12/19/11 03:27 PM
12/19/11 03:27 PM
Posts: 592 Sullivan, Ohio
Max Wedge Savoy
Sullivan, Ohio
"...pushed the reverse gear button by mistake..." sounds like this was a push button shift car. Do these have any reverse lockout feature from the factory? Is this still a potential hazard today for a push button trans car?
No. The only lockout is when the park lever is down in the park position.
[Re: Challenger 1]
#1139124
12/20/11 02:21 AM
12/20/11 02:21 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
From a drivers point of view, it is a safety issue not to put the car into neutral, because of the possibility of shifting into reverse.
From an engine builders point of view, you want to put the trans in neutral as you are lifting the throttle to protect the connecting rods - high RPM's and no load is when the rods are stressed the most and most likely to fail.
This is why many current valve bodies and shifters are reverse pattern, shifting away from park/reverse, and add a neutral at the rear of the pattern to make it pretty much impossible to hit reverse (or park) and still protect the rods.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: Evil Spirit]
#1139125
12/20/11 11:30 AM
12/20/11 11:30 AM
Posts: 7,506 Az
Crizila
Az
IMO, there was no need to pull that car out of gear. Ran those epeeds. Never had a rod problem.
Fastest 300
[Re: Evil Spirit]
#1139127
12/21/11 01:05 AM
12/21/11 01:05 AM
Posts: 2,431 SK,Canada
gregsrt
SK,Canada
That was in Alberta. I sold a 64 Dodge 330 post car to a guy from there a couple of years back. He said he had all the newspaper clippings from the crash. It happened when he was a kid. He bought my car to make a clone of that car. Not sure if he's started on it yet but he was pretty passionate about reproducing that car.
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry.
Thomas Jefferson
[Re: gregsrt]
#1139128
12/21/11 10:44 AM
12/21/11 10:44 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Tragic story. and yes, a 727 will lock up the rear wheels when shifted into reverse while driving at speed. happened to me. was driving along and my coil was going out, breaking down as the heat was building up, so I was getting popping, backfiring, etc. under load. while driving I was still trying to figure out what was going on...in neutral, it would rev and run just fine, sounded great. in gear it was surging and bucking. in my frustrated haste, I shifted from Drive to Neutral, with the intention of reving the engine to "clear it out" as that was seemingly helping for a little bit (again, I was still trying to figure out what was going on) I accidentally went too far and into reverse, locked up the rear wheels for about a second and a half. car got a little sideways, but not too bad, got it into neutral and coasted for a bit to gather myself up after freaking out (happened with a car coming at me in the other lane! imagine that...rears locked up, back end starts to step out, and you see a car coming at you 100 yards away and closing at 110 mph!)
anyway. I only did that once!
**Photobucket sucks**
[Re: Crizila]
#1139130
12/21/11 12:18 PM
12/21/11 12:18 PM
Evil Spirit
Newport, Mi
Apples to onions unless you ran those speeds back then - the accident happened in 1964. It would have been a lot more important then to protect the connecting rods back then - there were no Carillo, Eagle, Manley, etc. rods a credit card away in the mid 60's. Rod failures were common then - even getting good bolts were a luxury. And many trophy class racers commonly used the lightest rods they could find just for that little edge in HP and to help them rev just that little bit quicker.
Yes, back then with stock max wedge rods and bolts. Maybe I was just lucky
You might have been using a little more "user friendly" gear ratio and a tighter converter, too. Stock rods that tolerate tall tires and a 4.10 may become "alergic" to shorter tires and 5.38's.
