Re: Intake Manifold Part Number Help
[Re: Mikeymopar68]
#1127197
12/04/11 02:04 PM
12/04/11 02:04 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
i can't say for sure, but that part number seems to be telling the story. Maybe the person that said that, meant it will work on a 360.
I have mechanical Aptitude. I can screw up anything.
[Re: bboogieart]
#1127198
12/04/11 02:08 PM
12/04/11 02:08 PM
Posts: 75,095 A Banana Republic near you.
JohnRR
40 prefix tells you that is a very late 70's part number at the earliest, so if you are thinking it's a 340 manifold because of the last 3 digits don't , that's only on engine blocks ...
[Re: Mikeymopar68]
#1127199
12/04/11 02:10 PM
12/04/11 02:10 PM
JohnRR
I was given a cast iron intake manifold with the part number: 4100340-1. I was told it goes on a 360 but I cannot find out for sure. Anyone out there have more info on it? Thanks!
Do you have a set of intake gaskets ? If so throw one on there , 318 ports will be smaller than 360 ports otherwise measure the ports and post it up , someone should be able to tell you what it is .
Is it a 2bbl manifold or 4bbl ?
[Re: JohnRR]
#1127200
12/04/11 02:21 PM
12/04/11 02:21 PM
bboogieart
Lost and Spaced
Thanx John. I always learn something at this site.
