Intake Manifold Part Number Help #1127196
12/04/11 02:00 PM
12/04/11 02:00 PM
North Carolina
Mikeymopar68 Offline OP
North Carolina
I was given a cast iron intake manifold with the part number: 4100340-1. I was told it goes on a 360 but I cannot find out for sure. Anyone out there have more info on it? Thanks!
Re: Intake Manifold Part Number Help [Re: Mikeymopar68] #1127197
12/04/11 02:04 PM
12/04/11 02:04 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
i can't say for sure, but that part number seems to be telling the story.
Maybe the person that said that, meant it will work on a 360.
I have mechanical Aptitude.
I can screw up anything.
Re: Intake Manifold Part Number Help [Re: bboogieart] #1127198
12/04/11 02:08 PM
12/04/11 02:08 PM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
40 prefix tells you that is a very late 70's part number at the earliest, so if you are thinking it's a 340 manifold because of the last 3 digits don't , that's only on engine blocks ...
Re: Intake Manifold Part Number Help [Re: Mikeymopar68] #1127199
12/04/11 02:10 PM
12/04/11 02:10 PM
Do you have a set of intake gaskets ? If so throw one on there , 318 ports will be smaller than 360 ports otherwise measure the ports and post it up , someone should be able to tell you what it is .
Is it a 2bbl manifold or 4bbl ?
Re: Intake Manifold Part Number Help [Re: JohnRR] #1127200
12/04/11 02:21 PM
12/04/11 02:21 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Thanx John. I always learn something at this site.
Re: Intake Manifold Part Number Help [Re: JohnRR] #1127201
12/04/11 02:57 PM
12/04/11 02:57 PM
North Carolina
North Carolina
It's a 4 bbl intake.
Re: Intake Manifold Part Number Help [Re: Mikeymopar68] #1127202
12/05/11 01:52 PM
12/05/11 01:52 PM
dogdays Offline
dogdays  Offline
The casting number is too late for a 273, and I don't believe there were any "cop car" 4-barrel 318 intakes made with 318 ports. If there were they are extremely rare. What you have is a 360 intake even if it came on a 318. It's really heavy, has EGR provisions and is a very good intake for performance, better for example than an Edelbrock Performer. I'm using one like it on my 86 318 because I got it for $15. It's a spreadbore so I may end up using an adapter to use my 600 Holley. Mileage is a factor so a Q-jet or T-quad are also possibilities.
All in all, not a bad intake.
R.
