Page 1 of 3 1 2 3
explain 70 440 4bbl oval air cleaners w/air grabber.. #112105
08/29/08 01:34 PM
08/29/08 01:34 PM
delivering your oil
nutso suave Offline OP
delivering your oil
i am wondering what the deal is with 4bbl 'coyote duster' air cleaners for a 440 with an air grabber hood. does anyone have a picture of one? i want to install an air grabber on my hood (which has the vents) but i haven't been able to find the 4bbl air cleaner for this setup...i have seen them for the 383 (tony's sells one i think) but not for the 440. i know that the B/RB height difference won't allow you to use a 383 cleaner. is the baseplate the only difference? any photos of these? has anyone actually seen one? they seem more rare than the 6bbl these days!
i know the 440 4bbl wasn't offered in 69, but i don't have the money or the tuning ability for a six pack setup and i have a brand new 750 holley. if i use an aftermarket intake will the air cleaner be too tall? are there any aluminum intakes that have the same clearance? thanks...
Re: explain 70 440 4bbl oval air cleaners w/air grabber.. [Re: nutso suave] #112106
08/29/08 01:54 PM
08/29/08 01:54 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
The 440 air cleaner base is a bit shorter to allow for proper hood clearance. The 440 model is available as it was used on the GTX and Coronet R/T with fresh air option. These are the most difficult B body fresh air bases to find vs. 383 and the 6 pak model.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: explain 70 440 4bbl oval air cleaners w/air grabber [Re: 70gtx440dana] #112107
08/29/08 02:09 PM
08/29/08 02:09 PM
cataclysm80 Offline
cataclysm80  Offline
I think my 70 road runner came with a 440 4 bbl oval air cleaner & base. car is originally a 383 car, but I believe the airgrabber setup was added from a 440 4 bbl car, as the emblem at the rear of the hood says 440.
currently the car has a 400 2 bbl in it, but I have a built 383 waiting to go in that I would like to use the airgrabber with.
Does anyone have measurements, or some way to identify if I have a 440 4 bbl air cleaner setup, or the 383 4 bbl setup that I need?
Tav
Re: explain 70 440 4bbl oval air cleaners w/air grabber [Re: cataclysm80] #112108
08/29/08 02:12 PM
08/29/08 02:12 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Put the base on a level surface, If the front lip has an air gap, it's a 383. The lip on 440's will rest on the surface.
The difference in height is about 3/8"
Re: explain 70 440 4bbl oval air cleaners w/air grabber [Re: cataclysm80] #112109
08/29/08 02:54 PM
08/29/08 02:54 PM
delivering your oil
delivering your oil
cataclysm80-
keep me posted if it is the right one...i might have ulterior motives.
here is a link showing how to tell them apart (at the bottom of the page).
http://www.nicksgarage.com/aircleaner.htm#compare
can you post a pic? i think the 383 looks like this:
Re: explain 70 440 4bbl oval air cleaners w/air grabber.. [Re: nutso suave] #112110
08/29/08 04:51 PM
08/29/08 04:51 PM
DELAWARE
TONY_DAGOSTINO Offline
DELAWARE
AIR GRABBER BASEPLATE
HEIGHTS FROM BOTTOM OF BASE TO TOP OF CROSSBAR
1969 383 3-1/2”
1969 440 3”
70-2 383-400 2-1/2”
70-2 340-440 2”
Re: explain 70 440 4bbl oval air cleaners w/air grabber.. [Re: TONY_DAGOSTINO] #112111
08/29/08 05:59 PM
08/29/08 05:59 PM
cataclysm80 Offline
cataclysm80  Offline
I'll try and check mine out/maybe snap some pics this weekend.
Tav
Re: explain 70 440 4bbl oval air cleaners w/air grabber [Re: nutso suave] #112112
08/30/08 10:12 AM
08/30/08 10:12 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
FYI 69 is the only year the single 4 bbls used the oval air filter elemnet , 70 up used the same round air filter element as the 68-69 unsilenced assembly and a modified version of the 68-69 top on an oval base that had drain tubes ahead of the element ...
edit to remove confusion
Re: explain 70 440 4bbl oval air cleaners w/air grabber [Re: JohnRR] #112113
08/30/08 01:54 PM
08/30/08 01:54 PM
delivering your oil
delivering your oil
69 gtx then?
Re: explain 70 440 4bbl oval air cleaners w/air grabber.. [Re: nutso suave] #112114
08/30/08 06:03 PM
08/30/08 06:03 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
OK now that I have read the whole thing you ask about 70 air cleaner for your 1969 then confuse the issue more by adding a picture of a 69 style base .
To answer your last question , if you use ANYTHING other than a stock intake under a 69 hood with a stock height for the engine used filter assembly you run the risk of the air cleaner coming in contact and dimpling the hood .
You can use the holley but you have to use either a 70 style stock intake , lower thermo choke casting or modify the stock 68/69 choke thermo casting to clear the linakge on the holley .
Some will say that a CH4B will clear but I made that recommedation to NASBackyard and he dimpled his hood .
If you want to use anything but a stock height air cleaner and or a carb spacer you MUST MODIFY the the oval base by shortening the carb horn the appropriate amount. How much that is can only be determined with YOUR engine combo MOUNTED in YOUR CAR , I wouldn't trust ANY recommendation , MEASURE WHAT YOU HAVE .
YMMV
Re: explain 70 440 4bbl oval air cleaners w/air grabber [Re: JohnRR] #112115
08/30/08 06:20 PM
08/30/08 06:20 PM
delivering your oil
delivering your oil
i didn't realize there was a difference between the 69 and 70 air cleaners. i can appreciate the clearance issue, and measuring it yourself. i guess my best bet would be to leave the original intake and buy a 69 GTX oval air cleaner, modify my carb to fit, and go with that. i posted the picture of the 69 383 so people would have an idea of what i was talking about. maybe i'll forgo that idea and just make my own frankensteined airgrabber setup.
what is YMMV?
Re: explain 70 440 4bbl oval air cleaners w/air grabber [Re: nutso suave] #112116
08/30/08 06:29 PM
08/30/08 06:29 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
First YMMV is Your Mileage May Vary.. Second why not contact member Torred4speed as he makes fiberglass airgrabber bases for modified applications...Once it's painted it will look good to all but the most anal viewers & it will work fine..
Re: explain 70 440 4bbl oval air cleaners w/air grabber [Re: nutso suave] #112117
08/30/08 06:30 PM
08/30/08 06:30 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
make a prototype then go into production. If it fits good, works good, and looks good, I'll buy one. Provided you price it as if manufactured by chinese laborers earning $2.00/day.
Hey, I promise!
Re: explain 70 440 4bbl oval air cleaners w/air grabber.. [Re: cataclysm80] #112118
08/31/08 08:10 PM
08/31/08 08:10 PM
cataclysm80 Offline
cataclysm80  Offline
The nicksgarage link indicates it's a 383. ???
Re: explain 70 440 4bbl oval air cleaners w/air grabber.. [Re: cataclysm80] #112119
08/31/08 08:11 PM
08/31/08 08:11 PM
cataclysm80 Offline
cataclysm80  Offline
The nicksgarage link indicates it's a 383. ????
Re: explain 70 440 4bbl oval air cleaners w/air grabber.. [Re: cataclysm80] #112120
08/31/08 08:17 PM
08/31/08 08:17 PM
cataclysm80 Offline
cataclysm80  Offline
I've heard this lid decal is for 69 cars. ?????
Tav
Re: explain 70 440 4bbl oval air cleaners w/air grabber.. [Re: cataclysm80] #112121
08/31/08 08:24 PM
08/31/08 08:24 PM
cataclysm80 Offline
cataclysm80  Offline
here's a pic of the hood. You can see the 440 emblem at the bottom right of the pic.
car is a 70 roadrunner 383 4 speed plum crazy without N96 on the fender tag.
hood was on the car when I got it and is copper colored on the bottom. this is a 70 only hood right?
The pictured air cleaner was in the trunk.
the engine in the car was a 400 2 bbl
So, what do I have here?
Tav
Re: explain 70 440 4bbl oval air cleaners w/air grabber.. [Re: cataclysm80] #112122
08/31/08 08:52 PM
08/31/08 08:52 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
As stated previously just set the base on a flat surface & if it stands with only the carb throat area touching it's a 383 unit, if the front lip of the baseplate touches it's for a 440...Your lid is definately for a 69...
Re: explain 70 440 4bbl oval air cleaners w/air grabber [Re: cataclysm80] #112123
08/31/08 08:56 PM
08/31/08 08:56 PM
delivering your oil
delivering your oil
now i'm confused - that looks like a 383 69 air cleaner...
Re: explain 70 440 4bbl oval air cleaners w/air grabber [Re: nutso suave] #112124
08/31/08 09:24 PM
08/31/08 09:24 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
What are the 69 440 cleaners going for now? There is one for a 383 on the bag now at $255.
Page 1 of 3 1 2 3
