65 coronet steering box #1117925
11/20/11 06:47 PM
11/20/11 06:47 PM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
the power steering box on my 65 coronet is leaking , does someone rebuild them ? what all boxes fit the 65. Has anyone ever switched back to manual steering? i had a manual steering 69 road runner back in 77 but dont remember how hard they are to drive!
thanks Gene
Re: 65 coronet steering box [Re: 3wracing] #1117926
11/20/11 06:52 PM
11/20/11 06:52 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
I ditched all the power steering on my 65 long ago in favor of manual. I believe the pitmarm is unique to early B body cars. Not sure if others would work.
Youll need a manual steering shaft for your column, or the adaptor that extends the shaft. The OEM shaft can be added to your existing power column. Its not a difficult swap.
Re: 65 coronet steering box [Re: NTOLERANCE] #1117927
11/20/11 06:56 PM
11/20/11 06:56 PM
okla.
sam64 Offline
sam64  Offline
okla.
i put a firm feel manual on my 65 coronet,16.1,fine on rolling but pretty stiff at slow speeds.
Re: 65 coronet steering box [Re: 3wracing] #1117928
11/20/11 09:57 PM
11/20/11 09:57 PM
AndyF Offline
AndyF  Offline
The guys at Firm Feel can take care of you. www.firmfeel.com
Re: 65 coronet steering box [Re: AndyF] #1117929
11/20/11 11:42 PM
11/20/11 11:42 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Just a thought, what max RPM are you running?
Re: 65 coronet steering box [Re: NTOLERANCE] #1117930
11/23/11 06:33 PM
11/23/11 06:33 PM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
its a street car ,cruiser . maybe 5500 at times .
thanks Gene
Re: 65 coronet steering box [Re: 3wracing] #1117931
11/23/11 09:03 PM
11/23/11 09:03 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Just curious, as a friend of mine had a 65 plyouth with power steering, and we kept resealing the pump, lines ect, and it turned out to be he was spinning the pump too fast, and pumping the fluid out the reservoir.
Re: 65 coronet steering box [Re: NTOLERANCE] #1117932
11/24/11 09:58 AM
11/24/11 09:58 AM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
Another vote for Firm Feel. Amazing transformation.
