Re: 65 coronet steering box
[Re: 3wracing]
#1117926
11/20/11 06:52 PM
11/20/11 06:52 PM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
I ditched all the power steering on my 65 long ago in favor of manual. I believe the pitmarm is unique to early B body cars. Not sure if others would work.
Youll need a manual steering shaft for your column, or the adaptor that extends the shaft. The OEM shaft can be added to your existing power column. Its not a difficult swap.
[Re: AndyF]
#1117929
11/20/11 11:42 PM
11/20/11 11:42 PM
NTOLERANCE
Madison Wi
Just a thought, what max RPM are you running?
[Re: 3wracing]
#1117931
11/23/11 09:03 PM
11/23/11 09:03 PM
NTOLERANCE
Madison Wi
Just curious, as a friend of mine had a 65 plyouth with power steering, and we kept resealing the pump, lines ect, and it turned out to be he was spinning the pump too fast, and pumping the fluid out the reservoir.
