Re: Ported J head - Long head bolt crack - Quik on car fix
[Re: scatpacktom]
#1109866
11/09/11 12:28 AM
11/09/11 12:28 AM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
maybe drill the id of the bolt hole out a lil ..and get a piece of copper pipe with od same as id..and press it into the bolt hole. then re install new head bolt?
or something similar/ to that effect. cheapst.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: cheapstreetdustr]
#1109867
11/09/11 01:25 AM
11/09/11 01:25 AM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
http://www.ksmetals.com/retail.htmlK&S metals sold at ace hardware stores in Pa. My local store stocks the size that slides into the bold hole with a little bit of clearance. I apply JB weld to the tube and it works great. Don't forget that one bolt hole on each head supplies oil to the rocker gear and if it applies to the one you are tubing that issue will have to be addressed.
[Re: pittsburghracer]
#1109868
11/09/11 01:32 AM
11/09/11 01:32 AM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Don't forget to thoroughly clean the bolt hole with a piece of rag,thin screwdriver and some carb cleaner before driving the epoxied tube in the hole.
[Re: scatpacktom]
#1109872
11/10/11 03:38 AM
11/10/11 03:38 AM
Posts: 1,093 Long Beach, CA
Mike Swann
Long Beach, CA
just put some silicone under the bolthead.
8.30's @3400 lbs
[Re: Mike Swann]
#1109873
11/10/11 03:51 AM
11/10/11 03:51 AM
Posts: 2,128 sweden
sshemi
sweden
Or a washer and silicone
