Ported J head - Long head bolt crack - Quik on car fix #1109865
11/09/11 12:01 AM
11/09/11 12:01 AM
Phila Pa
scatpacktom Offline OP
Phila Pa
I have a crack in the long headbolt hole so oil is getting pumped into number one cylinder. Anyone have a quick and dirty way to keep from sucking the pan dry through the intake port?
Re: Ported J head - Long head bolt crack - Quik on car fix [Re: scatpacktom] #1109866
11/09/11 12:28 AM
11/09/11 12:28 AM
acworth / N. georgia - south e...
cheapstreetdustr Offline
maybe drill the id of the bolt hole out a lil ..and get a piece of copper pipe with od same as id..and press it into the bolt hole.
then re install new head bolt?
or something similar/ to that effect.
cheapst.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: Ported J head - Long head bolt crack - Quik on car fix [Re: cheapstreetdustr] #1109867
11/09/11 01:25 AM
11/09/11 01:25 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
http://www.ksmetals.com/retail.html
K&S metals sold at ace hardware stores in Pa.
My local store stocks the size that slides into the bold hole with a little bit of clearance. I apply JB weld to the tube and it works great. Don't forget that one bolt hole on each head supplies oil to the rocker gear and if it applies to the one you are tubing that issue will have to be addressed.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Ported J head - Long head bolt crack - Quik on car fix [Re: pittsburghracer] #1109868
11/09/11 01:32 AM
11/09/11 01:32 AM
PA.
"Little"John
"Little"John
PA.
Don't forget to thoroughly clean the bolt hole with a piece of rag,thin screwdriver and some carb cleaner before driving the epoxied tube in the hole.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Ported J head - Long head bolt crack - Quik on car fix [Re: pittsburghracer] #1109869
11/09/11 09:50 PM
11/09/11 09:50 PM
Phila Pa
Phila Pa
I found the tube from k+s John! That was a good tip. I hope I can get it together and Kick Some Tail. The tube measures .531 in case anybody else runs into this. My trouble is in the oil feed hole so I will put a couple of notches in the tube. Thanks for the heads up you bailed me out
Re: Ported J head - Long head bolt crack - Quik on car fix [Re: scatpacktom] #1109870
11/09/11 10:43 PM
11/09/11 10:43 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Will you be ready for Sunday??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Ported J head - Long head bolt crack - Quik on car fix [Re: scatpacktom] #1109871
11/09/11 10:54 PM
11/09/11 10:54 PM
PA.
"Little"John
"Little"John
PA.
No problem. Glad I could help.
Now go have some fun. I hope to get out myself this weekend.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Ported J head - Long head bolt crack - Quik on car fix [Re: scatpacktom] #1109872
11/10/11 03:38 AM
11/10/11 03:38 AM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
just put some silicone under the bolthead.
8.30's @3400 lbs
Re: Ported J head - Long head bolt crack - Quik on car fix [Re: Mike Swann] #1109873
11/10/11 03:51 AM
11/10/11 03:51 AM
sweden
sshemi Offline
sshemi  Offline
sweden
Or a washer and silicone
