help me choose engine parts for a low 11sec b-body #1107111
11/04/11 05:58 PM
11/04/11 05:58 PM
qc
mxbeep Offline OP
mxbeep  Offline OP
qc
i am looking for ideas on engine build/ setups for low 11 secs or even better 10's on 1/4 mile(assuming car as excellent traction)
car is original 440+6 b-body,4 speed,dana 60 3.73gears(richmond gears)and 3800lbs. aside for headers, i do not want any external modifications. i was thinking stroker crank, 440 source cnc ported stealth heads(painted orange), 11to1 comp and roller cam.
car must run on 94 octane pump gas to retain it streetability.
advice/opinions are very welcomed to which specific parts(especially cam choice) to purchase.
thanks
Re: help me choose engine parts for a low 11sec b-body [Re: mxbeep] #1107112
11/04/11 09:42 PM
11/04/11 09:42 PM
gregsdart Offline
gregsdart  Offline
The more cubes, the better. If you are going to do a stroker assembly, might as well go 7.10 H beam rods, 4.5 stroke. A light dished piston, ported small port aluminum heads, and a roller cam spec'd somewhere around 260 @ .050 on the intake will make for one mean street strip car. there are guys on here much better able to comment on the final cam combo, I am sure some will chime in. The limiting factor here will be the 6pak, so the extra cubes should help more than usual.
final result should be a motor you can shift at 5800 or so and will have gobs of torque from 3000 rpm up. I would also consider some aluminum main caps, and shoot for a light rotating assembly to help with block life.
Re: help me choose engine parts for a low 11sec b-body [Re: gregsdart] #1107113
11/04/11 10:11 PM
11/04/11 10:11 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i would give hughes a call on the cam. i bought 1 from them years ago. don't remember the specs. the cam they recommended really made my 493 scream. stay safe, seeya.
Re: help me choose engine parts for a low 11sec b-body [Re: rickraw] #1107114
11/04/11 10:21 PM
11/04/11 10:21 PM
qc
mxbeep Offline OP
mxbeep  Offline OP
qc
i forgot to mention that i want to keep internal oil pick, from what i read... im limited to low 500 cubic inches.
Re: help me choose engine parts for a low 11sec b-body [Re: gregsdart] #1107115
11/04/11 10:28 PM
11/04/11 10:28 PM
Indiana
Scott58 Offline
Scott58  Offline
Indiana
I just put a new 520 in my Road Runner for Drag Week this year: 4.375 crank, .030 over stock block, prepped with ARP main studs, 7.1 rods, .990 pin, 11.3 to one CR, ported "stealth" heads (by MCH), RAS 1.6 ratio rockers, MP.590 solid, 1/2" hemi pickup and hemi pan, stock valve covers (with some work to clear the rockers and hold down studs), 2" Super Comp headers, street dominator intake, HP950 carb. The engine is painted and other than the headers and the intake, it looks pretty stock (the intake doesn't even look that far off, I ground off the Holley markings on the front before painting). Drove it from Indiana to Kansas, ran Drag Week through Kansas, Oklahoma, Texas, and back to Kansas and then drove it home back to Indiana. Changed the oil once and checked the lash twice. Best ET: 11.36 at 120.2 , pig rich, with wheel spin at @ 3900# with me in it. Best MPH was 121.1 at @ 3850# with a soft launch (11.53ET) while I was getting a feel for the new setup.
I agree, go for max cubes, but for appearances you'll be limited to the stock block and probably a 4.375 crank unless you go external on the oil pickup. With better traction and a little lighter you should be a bit deeper into the low 11's and it is pretty reliable. You might want to consider having MCH rework the intake when they do the heads, you'll need the CFM with an engine this big. I think my engine might benefit from a bigger carb, and I could swap cams around some, but it works pretty good and is very streetable as is.
Re: help me choose engine parts for a low 11sec b-body [Re: mxbeep] #1107116
11/04/11 11:03 PM
11/04/11 11:03 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
My car should run 11.teens. .030 over 440 ross pistons (11.2:1) H-Beam rods, comp cams solid roller 588 cam, H/S 1.5 rockers, Ported stage VI heads, FACTORY 6-pack, Snow perf meth/h2o injection kit, tiny 1 3/4 headers, 3" exhaust, 3800 Turbo Action stall, 3.91's in an all steel 70 charger..except the glass "chevy" hood. Going to shoot for 10.9999 next year with 2" headers, more agressive tune, harder driving and traction bars.
Coming soon!!!!
Re: help me choose engine parts for a low 11sec b-body [Re: mxbeep] #1107117
11/04/11 11:08 PM
11/04/11 11:08 PM
AndyF Offline
AndyF  Offline
Talk to Dwayne at Porter Racing Heads. He does some FAST stuff so he'll be able to help with your combo. You don't even need the headers to run low 11's although using headers will open up the cam choices a bit.
I think the biggest issue is the clutch, not the engine. It isn't that hard to make enough power to run low 11's, the real trick is getting it to hook up at the track without eating itself on the street.
I never figured it out. I changed clutches a few times and finally gave up. I decided to run a clutch that lived on the street even it it ment losing some time at the track. An auto is probably a better choice but maybe someone has a clutch solution that they'll share.
Re: help me choose engine parts for a low 11sec b-body [Re: AndyF] #1107118
11/04/11 11:31 PM
11/04/11 11:31 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
I agree power is somewhat easy with all the hardware out there.
On the clutch contact HRS /Hyatt Racing Service. 440-254-1311
They don`t call him ClutchKing for nothing!
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: help me choose engine parts for a low 11sec b-body [Re: 6bblFLASH] #1107119
11/05/11 07:53 AM
11/05/11 07:53 AM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
Nice pic.
Re: help me choose engine parts for a low 11sec b-body [Re: BSB67] #1107120
11/05/11 09:27 AM
11/05/11 09:27 AM
gregsdart Offline
gregsdart  Offline
Twin disc clutch? Might be a good idea for getting some life out of it and be streetable.
Re: help me choose engine parts for a low 11sec b-body [Re: 6bblFLASH] #1107121
11/05/11 09:55 AM
11/05/11 09:55 AM
S.W. PA
6PACMAC Offline
6PACMAC  Offline
S.W. PA
And maybe slick shift or face plate the trans. Clean power shifts are a must to be quick. And 6pacs with vac pots gotta be w.o.t. the whole time.
Re: help me choose engine parts for a low 11sec b-body [Re: 6PACMAC] #1107122
11/05/11 12:43 PM
11/05/11 12:43 PM
AndyF Offline
AndyF  Offline
Yes, that works for going down the track but it kills the streetability.
I've just never seen a street/strip clutch that works well in both situations. The McLeod adjustable clutch can be made to work by crawling under the car and changing the static pressure, but that is a hassle. The dual disc stuff works great on the street but is pretty heavy for drag racing.
Re: help me choose engine parts for a low 11sec b-body [Re: mxbeep] #1107123
11/06/11 06:42 AM
11/06/11 06:42 AM
Adrian, Mi
P
pro6pakRR Offline
mopar addict
pro6pakRR  Offline
mopar addict
P
Adrian, Mi
My 70 road runner with a stock bore 440 11.5 compression,H beam rod edelbrock rpms out of the box,557 mopar cam,Crane gold 1.6 rockers,and a 6bbl.A 5000 stall converter,and 4.10 gears.At a weight with me in the car of 3895,has run a best of 11.53@117,on a 10.5 slick.
Don't forget that at 11.49 you have to have a roll bar.
Re: help me choose engine parts for a low 11sec b-body [Re: mxbeep] #1107124
11/06/11 06:59 AM
11/06/11 06:59 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
It should be easy. We run a NSS 65 Belvedere with only 446" 9.9 to1 comp,906 heads,edelbrock 2x4 intake,2 edelbrock 500cfm carbs(junk) would run faster with a single carb intake,4.10 gears,28" tire,8" PTC converter,3600+lbs 6.80's@100mph1/8 mile. Recently swapped the Comp street roller for an Ultradyne(Tim @ Bullet cams) and picked up .2 and 3 mph while keeping the idle nice. Good heads and more cubes should make it easy.
Re: help me choose engine parts for a low 11sec b-body [Re: pro6pakRR] #1107125
11/06/11 11:37 AM
11/06/11 11:37 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
My 70 road runner with a stock bore 440 11.5 compression,H beam rod edelbrock rpms out of the box,557 mopar cam,Crane gold 1.6 rockers,and a 6bbl.A 5000 stall converter,and 4.10 gears.At a weight with me in the car of 3895,has run a best of [Email]11.53@117[/Email],on a 10.5 slick.
still waiting for somebody to say something about that to me.
Re: help me choose engine parts for a low 11sec b-body [Re: Mr.Yuck] #1107126
11/06/11 01:25 PM
11/06/11 01:25 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Hey mr yuck your car is way faster than his
Re: help me choose engine parts for a low 11sec b-body [Re: Scott58] #1107127
11/06/11 03:09 PM
11/06/11 03:09 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
VERY cool! 11.30's and hundreds of highway miles...gotta love it!
I'l like to know about the rest of the combo: Trans, converter, gears if you don't mind.
Not to mention: PICS ! ! !
Re: help me choose engine parts for a low 11sec b-body [Re: RemCharger] #1107128
11/06/11 08:26 PM
11/06/11 08:26 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
not by much. Just hope they never look in when they hand me the slip. WHen I tech in I write 12.00 on the form.
Re: help me choose engine parts for a low 11sec b-body [Re: Mr.Yuck] #1107129
11/06/11 09:45 PM
11/06/11 09:45 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Read that wrong.
Thought you were looking for a pat on the back,,, not a slap on the hand
Re: help me choose engine parts for a low 11sec b-body [Re: RemCharger] #1107130
11/06/11 10:30 PM
11/06/11 10:30 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Mr Yuck dont you have a rollbar in your Charger ? Ron
My 63 is a basic 493 stroker that has got me 10.70's so far at 3700 lb. I use 440Source bottom end with dished pistons and main studs. It has 10.6 comp with the Indy EZ heads I use. Flat tappet cam thats 264 & 270 @ .050 with .624 and .630 lift with 1.6 rockers. Indy dual plane intake with an 850 DP. 2" TTI headers and 3" pipes out to the bumper. 727 with manual v/b and 9.5 Dynamic converter. 4.30's with a 30 x 9 Hoosier radial slick. It goes just over 3700 with me in it and has a best of 10.76 @ 124.49. Thats as I drive it thru the pipes on pump gas. Ron
