Re: help me choose engine parts for a low 11sec b-body
[Re: mxbeep]
#1107112
11/04/11 09:42 PM
11/04/11 09:42 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
The more cubes, the better. If you are going to do a stroker assembly, might as well go 7.10 H beam rods, 4.5 stroke. A light dished piston, ported small port aluminum heads, and a roller cam spec'd somewhere around 260 @ .050 on the intake will make for one mean street strip car. there are guys on here much better able to comment on the final cam combo, I am sure some will chime in. The limiting factor here will be the 6pak, so the extra cubes should help more than usual. final result should be a motor you can shift at 5800 or so and will have gobs of torque from 3000 rpm up. I would also consider some aluminum main caps, and shoot for a light rotating assembly to help with block life.
[Re: gregsdart]
#1107115
11/04/11 10:28 PM
11/04/11 10:28 PM
Posts: 174 Indiana
Scott58
Indiana
I just put a new 520 in my Road Runner for Drag Week this year: 4.375 crank, .030 over stock block, prepped with ARP main studs, 7.1 rods, .990 pin, 11.3 to one CR, ported "stealth" heads (by MCH), RAS 1.6 ratio rockers, MP.590 solid, 1/2" hemi pickup and hemi pan, stock valve covers (with some work to clear the rockers and hold down studs), 2" Super Comp headers, street dominator intake, HP950 carb. The engine is painted and other than the headers and the intake, it looks pretty stock (the intake doesn't even look that far off, I ground off the Holley markings on the front before painting). Drove it from Indiana to Kansas, ran Drag Week through Kansas, Oklahoma, Texas, and back to Kansas and then drove it home back to Indiana. Changed the oil once and checked the lash twice. Best ET: 11.36 at 120.2 , pig rich, with wheel spin at @ 3900# with me in it. Best MPH was 121.1 at @ 3850# with a soft launch (11.53ET) while I was getting a feel for the new setup.
I agree, go for max cubes, but for appearances you'll be limited to the stock block and probably a 4.375 crank unless you go external on the oil pickup. With better traction and a little lighter you should be a bit deeper into the low 11's and it is pretty reliable. You might want to consider having MCH rework the intake when they do the heads, you'll need the CFM with an engine this big. I think my engine might benefit from a bigger carb, and I could swap cams around some, but it works pretty good and is very streetable as is.
[Re: mxbeep]
#1107116
11/04/11 11:03 PM
11/04/11 11:03 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
My car should run 11.teens. .030 over 440 ross pistons (11.2:1) H-Beam rods, comp cams solid roller 588 cam, H/S 1.5 rockers, Ported stage VI heads, FACTORY 6-pack, Snow perf meth/h2o injection kit, tiny 1 3/4 headers, 3" exhaust, 3800 Turbo Action stall, 3.91's in an all steel 70 charger..except the glass "chevy" hood. Going to shoot for 10.9999 next year with 2" headers, more agressive tune, harder driving and traction bars.
[Re: AndyF]
#1107118
11/04/11 11:31 PM
11/04/11 11:31 PM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
I agree power is somewhat easy with all the hardware out there. On the clutch contact HRS /Hyatt Racing Service. 440-254-1311 They don`t call him ClutchKing for nothing!
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: 6bblFLASH]
#1107119
11/05/11 07:53 AM
11/05/11 07:53 AM
Posts: 4,316 Prospect, PA
BSB67
Prospect, PA
Nice pic.
[Re: 6bblFLASH]
#1107121
11/05/11 09:55 AM
11/05/11 09:55 AM
Posts: 915 S.W. PA
6PACMAC
S.W. PA
And maybe slick shift or face plate the trans. Clean power shifts are a must to be quick. And 6pacs with vac pots gotta be w.o.t. the whole time.
[Re: mxbeep]
#1107123
11/06/11 06:42 AM
11/06/11 06:42 AM
Posts: 1,153 Adrian, Mi
pro6pakRR
mopar addict
mopar addict
Adrian, Mi
My 70 road runner with a stock bore 440 11.5 compression,H beam rod edelbrock rpms out of the box,557 mopar cam,Crane gold 1.6 rockers,and a 6bbl.A 5000 stall converter,and 4.10 gears.At a weight with me in the car of 3895,has run a best of 11.53@117,on a 10.5 slick. Don't forget that at 11.49 you have to have a roll bar.
[Re: mxbeep]
#1107124
11/06/11 06:59 AM
11/06/11 06:59 AM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
It should be easy. We run a NSS 65 Belvedere with only 446" 9.9 to1 comp,906 heads,edelbrock 2x4 intake,2 edelbrock 500cfm carbs(junk) would run faster with a single carb intake,4.10 gears,28" tire,8" PTC converter,3600+lbs 6.80's@100mph1/8 mile. Recently swapped the Comp street roller for an Ultradyne(Tim @ Bullet cams) and picked up .2 and 3 mph while keeping the idle nice. Good heads and more cubes should make it easy.
[Re: pro6pakRR]
#1107125
11/06/11 11:37 AM
11/06/11 11:37 AM
Mr.Yuck
Brookeville, Md
My 70 road runner with a stock bore 440 11.5 compression,H beam rod edelbrock rpms out of the box,557 mopar cam,Crane gold 1.6 rockers,and a 6bbl.A 5000 stall converter,and 4.10 gears.At a weight with me in the car of 3895,has run a best of [Email]11.53@117[/Email],on a 10.5 slick. Don't forget that at 11.49 you have to have a roll bar.
still waiting for somebody to say something about that to me.
[Re: Mr.Yuck]
#1107126
11/06/11 01:25 PM
11/06/11 01:25 PM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
Hey mr yuck your car is way faster than his
[Re: Scott58]
#1107127
11/06/11 03:09 PM
11/06/11 03:09 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
VERY cool! 11.30's and hundreds of highway miles...gotta love it!
I'l like to know about the rest of the combo: Trans, converter, gears if you don't mind.
Not to mention: PICS ! ! !
[Re: RemCharger]
#1107128
11/06/11 08:26 PM
11/06/11 08:26 PM
Mr.Yuck
Brookeville, Md
not by much. Just hope they never look in when they hand me the slip. WHen I tech in I write 12.00 on the form.
[Re: Mr.Yuck]
#1107129
11/06/11 09:45 PM
11/06/11 09:45 PM
RemCharger
Sk. Canada
Read that wrong. Thought you were looking for a pat on the back,,, not a slap on the hand
