It should be easy. We run a NSS 65 Belvedere with only 446" 9.9 to1 comp,906 heads,edelbrock 2x4 intake,2 edelbrock 500cfm carbs(junk) would run faster with a single carb intake,4.10 gears,28" tire,8" PTC converter,3600+lbs 6.80's@100mph1/8 mile. Recently swapped the Comp street roller for an Ultradyne(Tim @ Bullet cams) and picked up .2 and 3 mph while keeping the idle nice. Good heads and more cubes should make it easy.
