Water temp #1101154
10/24/11 10:34 PM
10/24/11 10:34 PM
Bowling Green, KY
K
KY Charger Offline OP
K
Bowling Green, KY
I've got the water temp sending unit in the block of my 360 and haven't drove it over 5 miles yet but the temp hasn't reached over 170 either time, it has the 26" three row Champion with 2-12' fans and a 180 degree thermostat does anything sound funny, I was expecting at the most 190 degrees. It also has the flowkooler high volume water pump.
Re: Water temp [Re: KY Charger] #1101155
10/24/11 10:42 PM
10/24/11 10:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
At over 4 miles I would expect it to be opening the stat...
the stat might be partially open and moving fluid into
the radiator ... just a guess.... try driving farther
Re: Water temp [Re: KY Charger] #1101156
10/24/11 10:48 PM
10/24/11 10:48 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
my sender is in the pump hsg. i don't think having it in the block is any different. cover ur rad with a towel to increase the temp, then remove it & see if the temp stablizes. i think ur system is fine. stay safe, seeya.
Re: Water temp [Re: rickraw] #1101157
10/24/11 10:54 PM
10/24/11 10:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Will make a difference if the sender is on the rad
sid or block side of the stat... I dont know where
yours is located
Re: Water temp [Re: MR_P_BODY] #1101158
10/25/11 09:28 AM
10/25/11 09:28 AM
Bowling Green, KY
K
K
Bowling Green, KY
It's on the lower passenger side of the block, below the freeze plugs.
Re: Water temp [Re: KY Charger] #1101159
10/25/11 02:23 PM
10/25/11 02:23 PM
Put it up next to the thermostat housing so you can see how hot the coolant is leaving the motor Not entering the motor
Re: Water temp [Re: Cab_Burge] #1101160
10/25/11 09:02 PM
10/25/11 09:02 PM
Bowling Green, KY
K
K
Bowling Green, KY
Now Cab_Burge why didn't you tell me this sooner, but you have a very good point. Does anyone now what kind of temp sender to use with a weiand tunnel ram set-up then.
Re: Water temp [Re: KY Charger] #1101161
10/25/11 10:01 PM
10/25/11 10:01 PM
Guitar Jones Offline
I use the bypass hose hole in the intake and eliminate the bypass and thermostat on my SB. You can also get an adapter for the small Mopar temp sender hole or you can open it up and rethread it to a larger size.
Re: Water temp [Re: Cab_Burge] #1101162
10/25/11 10:52 PM
10/25/11 10:52 PM
Az
Crizila Offline
Crizila  Offline
Az
Yes, thats where it should be. Depending on where you measure it, block water temps can very as much as 80 degrees.
Fastest 300
