Re: Water temp
[Re: KY Charger]
#1101155
10/24/11 10:42 PM
10/24/11 10:42 PM
Posts: 52,972 Romeo MI
MR_P_BODY
At over 4 miles I would expect it to be opening the stat... the stat might be partially open and moving fluid into the radiator ... just a guess.... try driving farther
Re: Water temp
[Re: rickraw]
#1101157
10/24/11 10:54 PM
10/24/11 10:54 PM
MR_P_BODY
my sender is in the pump hsg. i don't think having it in the block is any different. cover ur rad with a towel to increase the temp, then remove it & see if the temp stablizes. i think ur system is fine. stay safe, seeya.
Will make a difference if the sender is on the rad sid or block side of the stat... I dont know where yours is located
Re: Water temp
[Re: KY Charger]
#1101161
10/25/11 10:01 PM
10/25/11 10:01 PM
Guitar Jones
I use the bypass hose hole in the intake and eliminate the bypass and thermostat on my SB. You can also get an adapter for the small Mopar temp sender hole or you can open it up and rethread it to a larger size.
