Re: Doug Nash 4 + 1 Trans
[Re: Dave W]
#1097768
10/19/11 10:04 PM
10/19/11 10:04 PM
Guitar Jones
Can you call Richmond and ask them?
[Re: Dave W]
#1097769
10/19/11 10:59 PM
10/19/11 10:59 PM
Posts: 672 Roanoke Va
gearjammerdart
Roanoke Va
I'm sure this question has been asked before. How much power can a Doug Nash 4 + 1 pro/slick shifted trans handle? Is it capable of handling 700-800 ft.lbs. of torque at the flywheel?
I would say no, but there are a lot of variables. Weight of the car is a big factor. Some of the DN have a center support bearing which makes them better, you can also have them sent off to have the shafts handcuffed together. The biggest problem that I found with the DN is that under a lot of power the counter shaft seperates and then you have gears breaking. A good clutch will help the trans live.
Donald
[Re: Dave W]
#1097771
10/20/11 12:50 AM
10/20/11 12:50 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
I don't know how much power they will take but I have broke mine a couple of times, the last time I shifted into 2nd while the wheels were still up from the launch, took out 2nd gear, bent the output shaft, split the case and oiled the track. Bought another , cheaper than the repair. And NO parts are for sale.
[Re: Dave W]
#1097772
10/20/11 08:12 AM
10/20/11 08:12 AM
Posts: 151 ohio
Rich970
ohio
check out g-force north ask for bubba. i have a 4 speed that works great for me. what clutch are you running ?
[Re: Dave W]
#1097775
10/20/11 03:54 PM
10/20/11 03:54 PM
Posts: 22,696 Bitopia
jcc
Bitopia
I got a richmond 5 sp FwIW and its rated 450lbs, which sounds very conservative IMO.
