Doug Nash 4 + 1 Trans #1097767
10/19/11 08:58 PM
10/19/11 08:58 PM
Glendale, AZ
Dave W Offline OP
Dave W  Offline OP
Glendale, AZ
I'm sure this question has been asked before. How much power can a Doug Nash 4 + 1 pro/slick shifted trans handle? Is it capable of handling 700-800 ft.lbs. of torque at the flywheel?
Re: Doug Nash 4 + 1 Trans [Re: Dave W] #1097768
10/19/11 10:04 PM
10/19/11 10:04 PM
Guitar Jones Offline
Can you call Richmond and ask them?
Re: Doug Nash 4 + 1 Trans [Re: Dave W] #1097769
10/19/11 10:59 PM
10/19/11 10:59 PM
Roanoke Va
gearjammerdart Offline
Roanoke Va
I would say no, but there are a lot of variables. Weight of the car is a big factor. Some of the DN have a center support bearing which makes them better, you can also have them sent off to have the shafts handcuffed together. The biggest problem that I found with the DN is that under a lot of power the counter shaft seperates and then you have gears breaking.
A good clutch will help the trans live.
Donald
69 Dart swinger 417 W8 Liberty 5 speed
6.03 @114/9.49 @141 on motor 5.30 @131 on juice 1/8th mile 28x10.5's at 3200lbs
70 Challenger RT 440 4-speed 4:10 Dana
http://www.youtube.com/watch?v=VowFy4nDdfI
Re: Doug Nash 4 + 1 Trans [Re: gearjammerdart] #1097770
10/19/11 11:12 PM
10/19/11 11:12 PM
Glendale, AZ
Dave W Offline OP
Dave W  Offline OP
Glendale, AZ
Car will weigh around 2800lbs. I would like a bullet-proof trans, what would be my best bet behind a power-adder small block with a budget of $3500?
Re: Doug Nash 4 + 1 Trans [Re: Dave W] #1097771
10/20/11 12:50 AM
10/20/11 12:50 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I don't know how much power they will take but I have broke mine a couple of times, the last time I shifted into 2nd while the wheels were still up from the launch, took out 2nd gear, bent the output shaft, split the case and oiled the track. Bought another , cheaper than the repair. And NO parts are for sale.
Re: Doug Nash 4 + 1 Trans [Re: Dave W] #1097772
10/20/11 08:12 AM
10/20/11 08:12 AM
ohio
Rich970 Offline
Rich970  Offline
ohio
check out g-force north ask for bubba. i have a 4 speed that works great for me. what clutch are you running ?
Re: Doug Nash 4 + 1 Trans [Re: Rich970] #1097773
10/20/11 09:12 AM
10/20/11 09:12 AM
Glendale, AZ
Dave W Offline OP
Dave W  Offline OP
Glendale, AZ
how much power can your G-Force handle?
Re: Doug Nash 4 + 1 Trans [Re: Dave W] #1097774
10/20/11 11:58 AM
10/20/11 11:58 AM
ohio
Rich970 Offline
Rich970  Offline
ohio
they say around 1000. depends ot the weight of the car . i am at 2800 lbs. hp ?
Re: Doug Nash 4 + 1 Trans [Re: Dave W] #1097775
10/20/11 03:54 PM
10/20/11 03:54 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I got a richmond 5 sp FwIW and its rated 450lbs, which sounds very conservative IMO.
