Lower Control Arm Bumper spacer #1097011
10/18/11 04:32 PM
10/18/11 04:32 PM
Canada
sassysixpack1 Offline OP
Canada
Hi all, what is the deal with the spacer below thw LCA bumper? I did a 6 pack Challenger a number of years ago, and now doing a 70 6 pack Super B and both these cars only had the spacer on one side. Is this correct or should they be on both sides ? If so, which side is correct ?
Re: Lower Control Arm Bumper spacer [Re: sassysixpack1] #1097012
10/19/11 12:59 AM
10/19/11 12:59 AM
Missouri
Big_E Offline
Big_E  Offline
Missouri
On the a12 Bees & RR they had one on each side. Not sure about yours.
Repro Spacers
Re: Lower Control Arm Bumper spacer [Re: Big_E] #1097013
10/19/11 01:30 AM
10/19/11 01:30 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
It depends on which wheels the car originally came with.
Re: Lower Control Arm Bumper spacer [Re: ScottSmith_Harms] #1097014
10/19/11 12:26 PM
10/19/11 12:26 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Scott - do tell
Re: Lower Control Arm Bumper spacer [Re: Morty426] #1097015
10/19/11 12:41 PM
10/19/11 12:41 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
That bump stop spacer was originally used on C-Body wagons with tall 78 series 15" tires for the GVWR. Then it was used on the A12 cars for the G70-15" tires to keep the tire from hitting the body/fender. Is there something in the front fender well that is different on one side versus the other that would require a little more limit and that's the reason? Was there an EVAP canister or something similar under one side that would be hit without the limiter/spacer?
MikeR
Re: Lower Control Arm Bumper spacer [Re: A12] #1097016
10/19/11 12:57 PM
10/19/11 12:57 PM
Canada
Canada
I could see a factory error, but on 2 different cars in the same shop ? Both are 70 V code cars, don't have serial numbers handy to check assembly plants.
Re: Lower Control Arm Bumper spacer [Re: sassysixpack1] #1097017
10/19/11 01:06 PM
10/19/11 01:06 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
If the spacers were on drivers side perhaps they figured there is always a driver so that side may bottom out more...
FWIW My 70 Challenger R/T SE U code had them on both sides... Originally equipped with 14" tires...
My T/A had them & my 71 Hemi Challenger had them...
Re: Lower Control Arm Bumper spacer [Re: 1_WILD_RT] #1097018
10/19/11 01:46 PM
10/19/11 01:46 PM
Canada
Canada
thanks for the info, I will put them on both sides and chalk it up to factory screw up !
Thanks.
Re: Lower Control Arm Bumper spacer [Re: Big_E] #1097019
10/19/11 07:18 PM
10/19/11 07:18 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Repro Spacers
The one on the left is an original, the one on the right is the reproduction I made.
I think Bill sells them: http://www.amhightechauto.com/
Re: Lower Control Arm Bumper spacer [Re: Dave Watt] #1097020
10/19/11 07:38 PM
10/19/11 07:38 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Bill Rolik sells them...http://www.billrolikenterprises.com/proddetail.asp?prod=2071727%2DP
