vinyl top. anyway to fix a few bubbles without redoing?
#109320
08/23/08 07:34 PM
08/23/08 07:34 PM
Posts: 1,523 Oakley CA
69charger440_6pa
Oakley CA
Hey,
is there anyway to fix a few small spots on a vinyl top that are lifting without having to redo the top?
Maybe a heat gun or somthing to try and soften the adhesive?
1969 Charger R/T under construction 2014 Ram 3500 Cummins 2006 Corvette Z06 2015 Corvette Z06 2014 BMW M5
Re: vinyl top. anyway to fix a few bubbles without redo
[Re: 340dart4spd ]
#109322
08/23/08 07:43 PM
08/23/08 07:43 PM
69charger440_6pa
Oakley CA
its not rust, its a newer install. I think it may have been lack of adhesive
[Re: 69charger440_6pa]
#109323
08/23/08 07:51 PM
08/23/08 07:51 PM
340dart4spd
Parts Problem
Parts Problem
[Re: 340dart4spd ]
#109324
08/23/08 07:53 PM
08/23/08 07:53 PM
69charger440_6pa
Oakley CA
there are a few in various places, some near the trim, some on the top of the roof. The more I look the more I find. Not sure why. Must not have used enough glue when I installed it. It went down flat when it was installed...... I hate vinyl.
[Re: BloFish]
#109326
08/23/08 08:00 PM
08/23/08 08:00 PM
69charger440_6pa
Oakley CA
I have noticed that if i push them they tack down for a few minutes, then they come back. Maybe a little heat would do the trick.
[Re: BloFish]
#109327
08/23/08 08:11 PM
08/23/08 08:11 PM
340dart4spd
Parts Problem
Parts Problem
Let it sit in the sun, and roll the bubbles with a rolling pin. Then, if you can, sit something on the bubbles to get it to lay flat
there you go....
Re: vinyl top. anyway to fix a few bubbles without redoing?
#109329
08/23/08 09:44 PM
08/23/08 09:44 PM
Posts: 1,822 Colorado
denfireguy
Colorado
Hey,
Here is what the 73 Cuda factory body manual says: Place strips of masking tape over the bubble. Use a hypodermic needle and syringe to insert 3M vinyl trim adhesive 8064 into bubble area. Avoid getting the adhesive on the top service (this is in bold black print). Remove needle and work adhesive to cover the area by pressing on the vinyl cover. Allow to dry 5 minutes at room temp. Heat bubble with low heat (150 to 160F) until the bubble area begins to enlarge in circumference. Inrared heat lamps provide suitable heat. Remove heat source allow cover to cool. A method of rapid cooling will be beneficial. Using a dry hypo, puncture the cover 4 times equally around the bubble to allow air and trapped solven to escape After bubble collapses, press cover to metal surface staring from one side of bubble and working toward the opposite side until it conforms to metal surfaces and all raise surfaces disappear. Keep vehicle from hot sunlight and other direce heat sources Examine top after a 24 hour period. That from the manual. Sounds like lots of fun work. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: denfireguy]
#109330
08/23/08 11:23 PM
08/23/08 11:23 PM
69charger440_6pa
Oakley CA
well so far I have been trying my heat gun and a roller, then quickley cooling the area and it seems to be working........ so far. Time will tell.
