vinyl top. anyway to fix a few bubbles without redoing? #109320
08/23/08 07:34 PM
08/23/08 07:34 PM
Oakley CA
69charger440_6pa Offline OP
Oakley CA
Hey,
is there anyway to fix a few small spots on a vinyl top that are lifting without having to redo the top?
Maybe a heat gun or somthing to try and soften the adhesive?
1969 Charger R/T under construction
2014 Ram 3500 Cummins
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: vinyl top. anyway to fix a few bubbles without redoing? [Re: 69charger440_6pa] #109321
08/23/08 07:37 PM
08/23/08 07:37 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
simple fix... remove trim peal it back...more then likely there is rust...then use adheasive to glue it back
Re: vinyl top. anyway to fix a few bubbles without redo [Re: 340dart4spd ] #109322
08/23/08 07:43 PM
08/23/08 07:43 PM
Oakley CA
Oakley CA
its not rust, its a newer install. I think it may have been lack of adhesive
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: vinyl top. anyway to fix a few bubbles without redo [Re: 69charger440_6pa] #109323
08/23/08 07:51 PM
08/23/08 07:51 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
where is it the bubble?
Re: vinyl top. anyway to fix a few bubbles without redo [Re: 340dart4spd ] #109324
08/23/08 07:53 PM
08/23/08 07:53 PM
Oakley CA
Oakley CA
there are a few in various places, some near the trim, some on the top of the roof. The more I look the more I find. Not sure why. Must not have used enough glue when I installed it. It went down flat when it was installed...... I hate vinyl.
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: vinyl top. anyway to fix a few bubbles without redo [Re: 69charger440_6pa] #109325
08/23/08 07:57 PM
08/23/08 07:57 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Let it sit in the sun, and roll the bubbles with a rolling pin. Then, if you can, sit something on the bubbles to get it to lay flat
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: vinyl top. anyway to fix a few bubbles without redo [Re: BloFish] #109326
08/23/08 08:00 PM
08/23/08 08:00 PM
Oakley CA
Oakley CA
I have noticed that if i push them they tack down for a few minutes, then they come back. Maybe a little heat would do the trick.
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: vinyl top. anyway to fix a few bubbles without redo [Re: BloFish] #109327
08/23/08 08:11 PM
08/23/08 08:11 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
there you go....
Re: vinyl top. anyway to fix a few bubbles without redo [Re: 340dart4spd ] #109328
08/23/08 09:08 PM
08/23/08 09:08 PM
Virginia
HemiStan Offline
HemiStan  Offline
Virginia
I have a couple of bubbles in mine as well from a lack of adhesive. I think that I am going to get some type of syringe with a needle, fill it with adhesive, and inject it into the bubble. Then, push if flat and see what happens. I've tried everything else.
Re: vinyl top. anyway to fix a few bubbles without redoing? [Re: 69charger440_6pa] #109329
08/23/08 09:44 PM
08/23/08 09:44 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Hey,
Here is what the 73 Cuda factory body manual says:
Place strips of masking tape over the bubble.
Use a hypodermic needle and syringe to insert 3M vinyl trim adhesive 8064 into bubble area. Avoid getting the adhesive on the top service (this is in bold black print).
Remove needle and work adhesive to cover the area by pressing on the vinyl cover.
Allow to dry 5 minutes at room temp.
Heat bubble with low heat (150 to 160F) until the bubble area begins to enlarge in circumference. Inrared heat lamps provide suitable heat.
Remove heat source allow cover to cool. A method of rapid cooling will be beneficial.
Using a dry hypo, puncture the cover 4 times equally around the bubble to allow air and trapped solven to escape
After bubble collapses, press cover to metal surface staring from one side of bubble and working toward the opposite side until it conforms to metal surfaces and all raise surfaces disappear.
Keep vehicle from hot sunlight and other direce heat sources
Examine top after a 24 hour period.
That from the manual.
Sounds like lots of fun work.
Craig
Re: vinyl top. anyway to fix a few bubbles without redo [Re: denfireguy] #109330
08/23/08 11:23 PM
08/23/08 11:23 PM
Oakley CA
Oakley CA
well so far I have been trying my heat gun and a roller, then quickley cooling the area and it seems to be working........ so far. Time will tell.
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: vinyl top. anyway to fix a few bubbles without redo [Re: HemiStan] #109331
08/24/08 07:35 AM
08/24/08 07:35 AM
pittsburgh,Pa.
mikepar Offline
mikepar  Offline
pittsburgh,Pa.
ditto sounds good to me thats wot i was thinkin
