First runs of Indy headed SB #1082732
09/25/11 11:17 PM
09/25/11 11:17 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Hey guys !
After lots of troubles and wrenching this summer, was finally able to do a couple of passes, best for the first night of 7.47 on a 1/8 mile track (4 runs in the evening).
Bad 1.666 60 ft
I know It can do a lot better !
With a few mods I wil do this week, post your comments on the combo and help go the right direction..
1967 barracuda 3300lbs with driver
408 sb 10.7:1 cr
Indy 360-1 heads 218 int runner 343 cfm ported
Indy intake ,
800 cfm holley #37 shooters,msd ign and coil
1 7/8 headers
1.6 rocker solid roller cam 255/263 @ .050
904 rebuilt trans low gearset 3800 stall
3.91 rear 28in drag slicks 9in wide
super stock spring with rancho shock set at 4
elect fan and water pump
shifting at 6200 rpm
any input to do better !
Dan
Re: First runs of Indy headed SB [Re: Wedgeman] #1082733
09/25/11 11:39 PM
09/25/11 11:39 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
6200 seems around 500 low to me for a head that flows 343 on 408 cubes
Re: First runs of Indy headed SB [Re: Wedgeman] #1082734
09/26/11 02:15 AM
09/26/11 02:15 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Hey guys !
Bad 1.666 60 ft
408 sb 10.7:1 cr
Indy intake ,
1 7/8 headers
Dan
With a cam like that i would think you'd need a higher flash stall, like somewhere around 4800. That 3800 is most likely your 60ft. issues, At 3300 lbs. & a combo like that you should be running 6.8-6.9s 1/8 mile, just to give you an example, there is a member on here with a 71 Swinger, its race weight is just below 3300 lbs., He is running a "junkyard" 360 magnum with EQ heads & a bone stock bottom end, 9.5.1, a smaller cam, around a 4200 stall, 4.10 gears & a 750dp & runs 7.4s.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: First runs of Indy headed SB [Re: emarine01] #1082735
09/26/11 02:21 AM
09/26/11 02:21 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Combo looks good. You should be shifting at 7k rpm. Even with a bad 60ft you should be well in the 10s with everything sorted out.
Re: First runs of Indy headed SB [Re: viperblue72] #1082736
09/26/11 11:00 AM
09/26/11 11:00 AM
Texas
dannysbee Offline
dannysbee  Offline
Texas
What was you MPH in the 1/8?
Getting old just means you were smarter than some and luckier than others.
Re: First runs of Indy headed SB [Re: joedust451] #1082737
09/26/11 11:07 AM
09/26/11 11:07 AM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
Hey guys !
Bad 1.666 60 ft
408 sb 10.7:1 cr
Indy intake ,
1 7/8 headers
Dan
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image] 9.100 @ 150 mph 5.780 @ 120 mph
Re: First runs of Indy headed SB [Re: nhramark] #1082738
09/26/11 11:21 AM
09/26/11 11:21 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
More gear 4.30s or 4.56s. Shift higher around 7000.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: First runs of Indy headed SB [Re: Wedgeman] #1082739
09/26/11 12:03 PM
09/26/11 12:03 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
IMHO you don't need the low gear set with the stroker. My pump gas 408 has gone 6.57 with a 1.38 60' at 3260#. The cam is a flat solid, 260/264 @ .050. I shift it at 6400. It's backed by a 727, with a 9.5" converter that flashes 6000 and a Dana with 4.10 gears.
Re: First runs of Indy headed SB [Re: justinp61] #1082740
09/26/11 07:16 PM
09/26/11 07:16 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
4.30 with 30 in tires ? or stay with 28.....?
Re: First runs of Indy headed SB [Re: Wedgeman] #1082741
09/26/11 08:28 PM
09/26/11 08:28 PM
Grand Rapids, MI
11secondC Offline
11secondC  Offline
Grand Rapids, MI
What was the mph? ET is in the chassis...but if the MPH is low...something's up with engine...
Re: First runs of Indy headed SB [Re: Wedgeman] #1082742
09/26/11 08:39 PM
09/26/11 08:39 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I'd stay with the 3.91s and a 28" tire. Most strokers don't need much gear. If it were mine I wouldn't do anything gear and tire wise until the engine and chassis was tuned. That car should run in the mid 6s in the 1/8.
Re: First runs of Indy headed SB [Re: Wedgeman] #1082743
09/27/11 12:31 AM
09/27/11 12:31 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
My 408 combo was close to that(you have 5* dur. more cam and a little more porting) was running 6.60s at 3300lbs with low 1.40s 60'
I can tell you mine liked 6700rpm shift points.
I ran a 9.5" converter 4600 stall, and 4.10 or 4.30 gears.
I would suggest that you try 6600 shifts, then go up 200 at a time tell it does not improve my
Also with the lowgear watchout for bumping the rev limiter in 1st gear {its easy to do)
"Just a Bracket car dressed up like a streetcar"
Re: First runs of Indy headed SB [Re: justinp61] #1082744
09/27/11 12:51 AM
09/27/11 12:51 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
My stroker(421) went 9.90s with 4.56s and 295/65/15(29in)hoosier drag radials. Tried 4.30s and it fell off.
Re: First runs of Indy headed SB [Re: 1967dartgt] #1082745
09/27/11 01:38 AM
09/27/11 01:38 AM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
What's the mph for your times?
Timing?
Fuel jetting? what fuel?
Cam lift?
The combination looks good, probably just needs some tuning... My 408 is as follows:
Nothing trick in the bottom end.
K1 forged crank, K1 rods, Diamond flat top pistons. Basic 408 bottom end. Compression calculated out to 10.3:1
Indy 360-2 CNC heads that have been massaged by Brett Miller (W5Dart66) and he also converted my intake to dominator flange
I believe they flow in the mid 330's at .700 lift
Solid roller camshaft by predator cams, 264/268@ .050, .698 gross lift
Engine runs best between 36-38 degrees of timing
1050 Dominator
Hedman 2" husler headers
727 with a transbrake
5400 ultimate converter
4.56s in a dana with 29.5x10.5 slicks
This is in a 3000# race weight 68 valiant with ladder bar rear suspension.
Went a best of 10.04 @ 131.xx at norwalk 2 weeks ago. Usually runs in the 10 teen or 20 range, depending on the air.
1/8 mile times in the 6.40s and 60' in the mid-high 1.30s depending on track
Re: First runs of Indy headed SB [Re: Wedgeman] #1082746
09/27/11 01:52 AM
09/27/11 01:52 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Keep what gears/tires you have now, I'd look into a higher stall & get to tuning it.
Re: First runs of Indy headed SB [Re: 1967dartgt] #1082747
09/27/11 07:02 AM
09/27/11 07:02 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
How much compression and cam?
Re: First runs of Indy headed SB [Re: justinp61] #1082748
09/27/11 09:04 AM
09/27/11 09:04 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
12 to 1 compression custom ground comp roller for nitrous 260/272 if I remember correctly. Had three different cams in that motor. And those passes were on motor with 9 1/2 dynamic conv tight for spray 3900-4000 stall.
Well I looked and memory was a little off, 272/284 ,110 lobe separation,and 660/661 gross lift.
Re: First runs of Indy headed SB [Re: 1967dartgt] #1082749
09/27/11 06:29 PM
09/27/11 06:29 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Great infos..
Keep in mind I have a low gearset....
So may be a 4.10 with 30in tires ?
Re: First runs of Indy headed SB [Re: Wedgeman] #1082750
09/27/11 07:04 PM
09/27/11 07:04 PM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
Here is my dart with eddy heads and a solid cam. I also run a 904 and a low 1st gear and 4.56 rearend gear. Has been 10.06 @ 131 pulling a huge wheelie at 3130 lbs. I shift at 6800 and the car traps at 7000 rpm on a 29.5 10.5 tire.
http://youtu.be/zd3TadLVg9E
http://youtu.be/N6v55H0vriw
Re: First runs of Indy headed SB [Re: WheelsUp73] #1082751
09/27/11 07:08 PM
09/27/11 07:08 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Yea mine also had low gear set in a 904.
