First runs of Indy headed SB
#1082732
09/25/11 11:17 PM
09/25/11 11:17 PM
Posts: 1,522 Ste-Sophie, Quebec, Canada
Wedgeman
Hey guys ! After lots of troubles and wrenching this summer, was finally able to do a couple of passes, best for the first night of 7.47 on a 1/8 mile track (4 runs in the evening).
Bad 1.666 60 ft
I know It can do a lot better !
With a few mods I wil do this week, post your comments on the combo and help go the right direction..
1967 barracuda 3300lbs with driver 408 sb 10.7:1 cr Indy 360-1 heads 218 int runner 343 cfm ported Indy intake , 800 cfm holley #37 shooters,msd ign and coil 1 7/8 headers 1.6 rocker solid roller cam 255/263 @ .050 904 rebuilt trans low gearset 3800 stall 3.91 rear 28in drag slicks 9in wide super stock spring with rancho shock set at 4
elect fan and water pump shifting at 6200 rpm
any input to do better !
Dan
Re: First runs of Indy headed SB
[Re: Wedgeman]
#1082734
09/26/11 02:15 AM
09/26/11 02:15 AM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
Bad 1.666 60 ft
Dan
With a cam like that i would think you'd need a higher flash stall, like somewhere around 4800. That 3800 is most likely your 60ft. issues, At 3300 lbs. & a combo like that you should be running 6.8-6.9s 1/8 mile, just to give you an example, there is a member on here with a 71 Swinger, its race weight is just below 3300 lbs., He is running a "junkyard" 360 magnum with EQ heads & a bone stock bottom end, 9.5.1, a smaller cam, around a 4200 stall, 4.10 gears & a 750dp & runs 7.4s.
[Re: viperblue72]
#1082736
09/26/11 11:00 AM
09/26/11 11:00 AM
Posts: 5,160 Texas
dannysbee
Texas
What was you MPH in the 1/8?
Getting old just means you were smarter than some and luckier than others.
[Re: joedust451]
#1082737
09/26/11 11:07 AM
09/26/11 11:07 AM
Posts: 3,104 Wheels up, MO
nhramark
Wheels up, MO
Bad 1.666 60 ft
Dan
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image]
9.100 @ 150 mph
5.780 @ 120 mph
[Re: nhramark]
#1082738
09/26/11 11:21 AM
09/26/11 11:21 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
More gear 4.30s or 4.56s. Shift higher around 7000.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: Wedgeman]
#1082742
09/26/11 08:39 PM
09/26/11 08:39 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
4.30 with 30 in tires ? or stay with 28.....?
I'd stay with the 3.91s and a 28" tire. Most strokers don't need much gear. If it were mine I wouldn't do anything gear and tire wise until the engine and chassis was tuned. That car should run in the mid 6s in the 1/8.
[Re: Wedgeman]
#1082743
09/27/11 12:31 AM
09/27/11 12:31 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
My 408 combo was close to that(you have 5* dur. more cam and a little more porting) was running 6.60s at 3300lbs with low 1.40s 60' I can tell you mine liked 6700rpm shift points. I ran a 9.5" converter 4600 stall, and 4.10 or 4.30 gears. I would suggest that you try 6600 shifts, then go up 200 at a time tell it does not improve my Also with the lowgear watchout for bumping the rev limiter in 1st gear {its easy to do)
"Just a Bracket car dressed up like a streetcar"
[Re: Wedgeman]
#1082746
09/27/11 01:52 AM
09/27/11 01:52 AM
joedust451
super gas
super gas
Branson, Mo.
Keep what gears/tires you have now, I'd look into a higher stall & get to tuning it.
[Re: 1967dartgt]
#1082747
09/27/11 07:02 AM
09/27/11 07:02 AM
justinp61
W. Kentucky
My stroker(421) went 9.90s with 4.56s and 295/65/15(29in)hoosier drag radials. Tried 4.30s and it fell off.
How much compression and cam?
[Re: justinp61]
#1082748
09/27/11 09:04 AM
09/27/11 09:04 AM
1967dartgt
Hilltown Pa
12 to 1 compression custom ground comp roller for nitrous 260/272 if I remember correctly. Had three different cams in that motor. And those passes were on motor with 9 1/2 dynamic conv tight for spray 3900-4000 stall.
Well I looked and memory was a little off, 272/284 ,110 lobe separation,and 660/661 gross lift.
[Re: WheelsUp73]
#1082751
09/27/11 07:08 PM
09/27/11 07:08 PM
1967dartgt
Hilltown Pa
Yea mine also had low gear set in a 904.
