Starter Relocation Kit For a Lakewood Bellhousing #1073315
09/11/11 08:07 PM
09/11/11 08:07 PM
Maryville tn
67coronetman Offline OP
Maryville tn
Can anyone give me real valuable info on how to best use & install the starter relocation kit cause i really am not understanding.! Or did someone out here find a way to make it work with out it.!
Old car are me......
Re: Starter Relocation Kit For a Lakewood Bellhousing [Re: 67coronetman] #1073316
09/12/11 08:10 PM
09/12/11 08:10 PM
Maryville tn
Maryville tn
I would really appreciate it if someone has some info & yes i have looked at lakewood bellhousing site.!
Re: Starter Relocation Kit For a Lakewood Bellhousing [Re: 67coronetman] #1073317
09/12/11 09:57 PM
09/12/11 09:57 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
What do you mean by starter relocation kit ? What size is your flywheel ?
Re: Starter Relocation Kit For a Lakewood Bellhousing [Re: JohnRR] #1073318
09/12/11 10:15 PM
09/12/11 10:15 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
If you're talking about the cup/bolt that captures the starter nose it's just a matter of bolting it in the innermost hole for a 130 tooth flywheel, outer hole for a 143 tooth wheel. If that's not what you're describing...Dunno?
Re: Starter Relocation Kit For a Lakewood Bellhousing [Re: Bill MeLater] #1073319
09/12/11 10:24 PM
09/12/11 10:24 PM
JohnRR Offline
JohnRR  Offline
Isn't there also a piece that bolts to the bell that grabs a starter bolt to hold the starter in the correct location along with the nose cup ?
Re: Starter Relocation Kit For a Lakewood Bellhousing [Re: JohnRR] #1073320
09/12/11 10:43 PM
09/12/11 10:43 PM
Wisconsin USA
Wisconsin USA
Mine just has a single top bolt location and 2 on the bottom for locating the starter to match the flywheel. Can't say for sure that's the only way they ever made 'em??
Re: Starter Relocation Kit For a Lakewood Bellhousing [Re: Bill MeLater] #1073321
09/12/11 11:43 PM
09/12/11 11:43 PM
Maryville tn
Maryville tn
Thanks for the replies i looked at my bellhousing and its the wrong one that is why it didn't work! i have the right bellhousing coming.
Re: Starter Relocation Kit For a Lakewood Bellhousing [Re: JohnRR] #1073322
09/13/11 03:49 AM
09/13/11 03:49 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Yes, I had to use it on my lower starter bolt....440 with 130 tooth.(correction = not 143)
Re: Starter Relocation Kit For a Lakewood Bellhousing [Re: JohnRR] #1073323
09/14/11 04:21 PM
09/14/11 04:21 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
there is and used with 130T only. here's a pic
Re: Starter Relocation Kit For a Lakewood Bellhousing [Re: 446acuda] #1073324
09/14/11 04:22 PM
09/14/11 04:22 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
Here is a top view. The bottom starter bolt hole gets into the starter pocket so there is no room for a bolt hole on the bellhousing.
Re: Starter Relocation Kit For a Lakewood Bellhousing [Re: 446acuda] #1073325
09/14/11 04:23 PM
09/14/11 04:23 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
adapter piece
Re: Starter Relocation Kit For a Lakewood Bellhousing [Re: 446acuda] #1073326
09/14/11 04:25 PM
09/14/11 04:25 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
starter mounted for 143 tooth wheel. No adapter needed
Re: Starter Relocation Kit For a Lakewood Bellhousing [Re: 446acuda] #1073327
09/14/11 05:58 PM
09/14/11 05:58 PM
fury4speed Offline
fury4speed  Offline
So the adapter is used with a 130 Tooth Flywheel only if your using a scatter shield? thanks.
Re: Starter Relocation Kit For a Lakewood Bellhousing [Re: fury4speed] #1073328
09/14/11 06:10 PM
09/14/11 06:10 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
yes, if you have a Lakewood scattershield with the 2 starter cup holes then the adapter is used only with the 130 tooth flywheel(inner hole). There are bb lakewood scattershields that use a 130 tooth flywheel only and don't need any adapter or starter cup since they just use a big hole in the starter pocket to support the starter nose.
